2005 5.4 Triton, HELP
Old 06-11-2014, 01:38 PM
SPS7's Avatar
SPS7
SPS7 is offline
I have a 2005 FX4 with a 5.4 Triton, it has a little over 200,000 on it. Last week it started getting a little doggy when idiling and i was backing out of driveway and it almost died and the check engine light came on. called local town mechanic and he said that he wouldnt work on this year and motor. i went to oreillys and they read the code and it was P0506, idle air control valve. the only thing is the 5.4 doesnt have a idle control? is there anything i can clean or look at? help much appreciated!
Old 06-11-2014, 07:42 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
That code means the PCM can't control the idle speed. Most likely the throttle body has carbon deposits restricting the airflow at idle. Take the TB off and clean it real good with some carb cleaner and a old toothbrush.
Old 06-11-2014, 09:36 PM
Milly1219's Avatar
Milly1219
Milly1219 is offline
Hope it works
I'm having exact same problem, coughing and sputtering at idle. Would you mind posting any results you have. I changed my plugs yesterday.. $1100 later, I still have idle trouble.
samahi72
09-23-2014 06:21 PM
gymbo88
2004 - 2008 F150
01-19-2013 08:53 PM
cowboy1997
1997 - 2003 F150
02-19-2010 06:44 PM
nothingbutford
1999 to 2016 Super Duty
07-04-2004 12:34 AM
Quick Reply: 2005 5.4 Triton, HELP
