I just installed a new Intake manifold
It's a Weiand 8023 for my 351W powered "convertible". It was something I was putting off for a while, but now it's done and I'm very glad to be free of the little oil seepage, and I will admit..some actual water seepeage too I found out.
85" 4-wheel convertible power-plant
All is well now , but with the 1" phenolic spacer for my Holley street Avenger, I have found that my OEM big air cleaner just won't fit anymore. I'm not sure what to do about that since I just went to the trouble of a new ATS switch for the air intake door (cold /hot) etc.
Any quick thoughts about this?...I have the usual way to fix it of course.
If anyone is in southern Oregon wanting or needing a working OEM HO cleaner...it could be yours for a small donation..
Best wishes for those working on their rigs today...
Also, why the spacer installation?
Yes maybe 1/2" might help, I hadn't thought about that. I should probably add that my machinist-hotrod guru talked me into blocking the exhaust flow neath the carb as well. It will run great this summer..and I'm familiar with what the winter can bring here especially when conditions are right.
That being said, I have followed the air/ground temps pretty closely and I DO live in a pretty mild winter climate for this state..
I should go measure the air cleaner I guess and see just how much it would take to fit.
Well, the basically the a/c hose routing is in the way on the firewall, and I like the phenolic spacer for heat issues..but I will admit, this manifold already is pretty tall.
Thanks for the input guys
Hi Gary...Yes I have an HO cleaner. Tidy is the way my a/c hoses are now as well..are you saying maybe I should try a smaller stock air cleaner?
here's a pic
HO air cleaner interference with firewall
I may be able to get there with a 1/2 spacer and moving the hoses..but I really don't want to do either...
I guess this problem has never been solved before?...I DO realize the 1" spacer adds a little mud to the water
Good to know this, it looks like a standard cleaner is what I'm looking for..thanks Gary..I'll get on the hunt..maybe I'll find what I need before winter.
