DEF in a 6.0?? - Ford Truck Enthusiasts Forums
DEF in a 6.0??
Old 06-11-2014, 09:52 AM
SVTDriver97's Avatar
SVTDriver97 SVTDriver97 is offline
SVTDriver97 is gaining momentum as a positive member of FTE.
DEF in a 6.0??
Hey guys, i'm normally on the 80-86 forums but decided to pop over here real quick and ask a question.
Forgive me if this has already been asked before...
Is it possible to make an older Powerstroke able to use Diesel Exhaust Fluid (DEF)??
The reason why i'm asking is that my dad and I recently rented a new Ram with a Cummins to go on an extended road trip, and I noticed that the truck takes DEF, and I also noticed that while it's running, there's no 'diesel smell' coming from the tail pipe!! I was amazed!!
Both my dad and I are a little allergic to diesel fumes, so driving a diesel truck has never been something we'd consider, but the mileage and quietness of that diesel motor plus the added bonus of no fumes, it has changed our view of diesel trucks.
I personally like the 99-07 Super Duties, and if I can make one into a non-smelly truck, then that'll have to be my next truck.
Thanks
Old 06-11-2014, 09:55 AM
jswartz84's Avatar
jswartz84 jswartz84 is online now
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
I'm sure you could with lots of time and money. The 6.0s have an emissions system on it, so naturally, they are less smelly then a 7.3.
Oh, the newer diesels stink way worse when the regen!!!
Old 06-11-2014, 10:02 AM
Quote:
What do you mean by newer diesels? Do you mean the 6.7's? Because I know those have DEF, and don't stink either.
Old 06-11-2014, 10:31 AM
jswartz84's Avatar
Quote:
Yep, the 6.4s, 6.7s, and the 6.7 Cummins, when the regen, they about make me puke. And thats even in the air 20 feet above them.
Old 06-11-2014, 10:34 AM
KDAVID1's Avatar
KDAVID1 KDAVID1 is offline
KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.
On my 6.0 the only time I smell diesel is when I fill up, change fuel filters, and when I had the leak on the fuel regulator cover before I fixed it.
Old 06-11-2014, 10:38 AM
But if the new 6.7 Powerstrokes use DEF, is there still a need for it to regen?
Please forgive me, but I am a complete diesel newby. Don't know much about them at all. Not familiar with common issues, or behavior of them either.
Rather than ask you what regen was, I googled it so I learned something there .
Old 06-11-2014, 10:39 AM
Quote:
What about if you're working behind or around it? Won't it smell pretty good while, let's just use an example: hooking up a trailer?
Old 06-11-2014, 10:51 AM
jswartz84's Avatar
Even if they don't regen, they stink after working around the within an hour while using the PTO function.
Old 06-11-2014, 10:58 AM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
The half of the question that wasn't answered is noise -- we kinda find it sweet, but you aren't going to make it quiet like the new trucks as most of it is under the hood. I'd go check out the 6.7 forum -- all those guys talk about is how humongous their trailers are, not much is breaking on the latest ones.
And they are really quiet, if that is part of what you want
Old 06-11-2014, 11:02 AM
KDAVID1's Avatar
Nope. You get exhaust smell but it's not the diesel stink. Least not to me.
Old 06-11-2014, 11:07 AM
That is kind of part of it, but honestly...i'm kind of a fan of the noise the 6.0's make. Especially when they have something done where you can hear the turbo whistle, not sure what it takes to get that sound, but I do enjoy that for sure.
My main beef is with the smell, and was just curious of if it could be done to a 6.0?
Old 06-11-2014, 11:09 AM
That's what i'm talking about, the exhaust smell.
When we took our road trip and were hooking up the trailer, I was fully prepared to be sneezing and coughing the rest of the way there, but because of the DEF, I couldn't smell ANY exhaust smell!!
That's why i'm curious if it can be done to an older truck. From what I can gather, all that is happening is the DEF is being lightly sprayed into the hot exhaust which then causes a chemical reaction where the only thing coming from the tail pipe is nitrogen and oxygen.
Old 06-11-2014, 11:18 AM
KDAVID1's Avatar
Well I supose if your problem is exhaust smell not really diesel smell then yeah it has it. I personally havent huffed one of the new 6.7s but It makes sense. I do know those systems they use are VERY EXPENSIVE to repair so could only imagine the price to try and engineer and retro fit a 6.0.
Old 06-11-2014, 11:54 AM
Good point.
Old 06-11-2014, 12:03 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
As someone who grew up on IDIs, I can tell you the 6.0 has a lot less diesel exhaust smell than older diesels, even without using DEF. If you want smelly, try working around an old GM 6.2 -- or better yet, a Deuce and a half.
2016 f350 diesel emery1228 1999 to 2016 Super Duty 5 11-08-2016 03:16 PM
Wal-Mart DEF Jugs warning Dakster 6.7L Power Stroke Diesel 35 08-04-2016 07:25 AM
Fumes in the cab once in a while Str8shooter 6.7L Power Stroke Diesel 10 03-09-2015 01:29 PM
Fuel vandalism Coopers_dad 6.7L Power Stroke Diesel 16 01-17-2015 04:25 PM
Remove DEF System only without Tuning? B&LLandscaping 6.7L Power Stroke Diesel 16 08-24-2012 11:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
