460 block with no casting numbers ( 460 ?)
Old 06-11-2014, 12:51 AM
Nevada Mike's Avatar
Nevada Mike
Nevada Mike is offline
Greetings from Nevada.
I had the opportunity to purchase a new Scat Steel Crank, 4.500 stroke. The guy also threw in a block he was going to build with this crank. The numbers of 572ci grabbed my attention. Anyway...
The block has no casting numbers, the freeze plugs are threaded and the block has 4 bolt mains. The outside bolts are smaller than the bolts that would be normal 2 bolt fashion.
There is a random "3" on one side and maybe, if I remember right, a "1".
That's it !! What do I have here ?? I took a crude measurement, with a tape measure, of the bores diameter. Just shy of 4.500
Old 06-11-2014, 10:03 PM
Nevada Mike
47 views and not even one educated guess.
This is a Ford Forum right ??
Old 06-12-2014, 01:28 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Ford trucks. Welcome to FTE.
Most 460 inquiries here are how to get better mpg, how to fix, pass smog, or make serious horsepower without actually doing anything serious to the engine.
Not many with custom blocks, which is what I would bet you have there. See if you can match it up features wise:
Eliminator Performance Products Premier Engine Block
The only other block I found was Ford SVO or racing, which is bound to have a Ford id on it. Discussion here:
Eliminator ultra vs. A-460 block ?'s - 460 Ford Forum
Which, by the way, takes you to "all 460 all the time", where you might get more info on your block. Maybe.
There are a couple guys here who have raced these motors, so stand by you may get more responses, as your thread is back to the top.
Good luck with it!
Old 06-12-2014, 03:13 PM
cbakker's Avatar
cbakker
cbakker is offline
Is it a siamese bore? If it were an A460 or an A460BB, it would have casting numbers on it from FRPP on it. I am no expert on the aftermarket blocks, and your best bet is to try the boys over at 460ford.com, lots of builder there that would tell you right away what it is.
Old 06-13-2014, 04:08 PM
Nevada Mike
Thanks for the links and the replies. Much appreciated.
1986F350witha7.3
05-31-2011 02:20 PM
55 f250
04-23-2009 05:46 AM
nofortunateson
12-10-2007 04:27 PM
tom1979
01-21-2007 11:15 AM
ivanribic
01-24-2004 05:38 PM
Quick Reply: 460 block with no casting numbers ( 460 ?)
