460 block with no casting numbers ( 460 ?) - Ford Truck Enthusiasts Forums
Old 06-11-2014, 01:51 AM
Nevada Mike Nevada Mike is offline
Nevada Mike is starting off with a positive reputation.
Greetings from Nevada.
I had the opportunity to purchase a new Scat Steel Crank, 4.500 stroke. The guy also threw in a block he was going to build with this crank. The numbers of 572ci grabbed my attention. Anyway...
The block has no casting numbers, the freeze plugs are threaded and the block has 4 bolt mains. The outside bolts are smaller than the bolts that would be normal 2 bolt fashion.
There is a random "3" on one side and maybe, if I remember right, a "1".
That's it !! What do I have here ?? I took a crude measurement, with a tape measure, of the bores diameter. Just shy of 4.500
Old 06-11-2014, 11:03 PM
47 views and not even one educated guess.
This is a Ford Forum right ??
Old 06-12-2014, 02:28 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Ford trucks. Welcome to FTE.
Most 460 inquiries here are how to get better mpg, how to fix, pass smog, or make serious horsepower without actually doing anything serious to the engine.
Not many with custom blocks, which is what I would bet you have there. See if you can match it up features wise:
Eliminator Performance Products Premier Engine Block
The only other block I found was Ford SVO or racing, which is bound to have a Ford id on it. Discussion here:
Eliminator ultra vs. A-460 block ?'s - 460 Ford Forum
Which, by the way, takes you to "all 460 all the time", where you might get more info on your block. Maybe.
There are a couple guys here who have raced these motors, so stand by you may get more responses, as your thread is back to the top.
Good luck with it!
Old 06-12-2014, 04:13 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Is it a siamese bore? If it were an A460 or an A460BB, it would have casting numbers on it from FRPP on it. I am no expert on the aftermarket blocks, and your best bet is to try the boys over at 460ford.com, lots of builder there that would tell you right away what it is.
Old 06-13-2014, 05:08 PM
Thanks for the links and the replies. Much appreciated.
360 stroker head help yohon FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 09-03-2016 09:08 AM
Clevor info brehenkel 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-03-2015 08:45 PM
445 cube big block FE in a 96 Ranger extended cab Ford FE guy Engine Swaps 2 08-27-2014 02:27 AM
Cast vs. Forged Cranks jseim44 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 03-23-2012 08:51 PM
Which Damper for a Scat Crankshaft ???? jamies460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 06-12-2010 07:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
