Go to START truck and it has no voltage - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-11-2014, 12:06 AM
SouthernBuckers SouthernBuckers is offline
SouthernBuckers is starting off with a positive reputation.
Sometimes I go to start my truck and it will start and run fine but then when I go back to start it will not start because it acts like it has no voltage. All the lights in the dash are dim even the wait to start. It will not even have enough voltage to put my window up. I ca hear it clicking under the dash between the the steering column and the radio. Sometimes the clicking will go off and sometimes it will keep clicking for long periods. If I shut the door or just push in the button at the door it will quit clicking but still will not have enough volts to think about starting the truck. Is there a certain wire harness under the dash that is prone to having problems and could be shorting out? Thanks for any help!
Old 06-11-2014, 12:20 AM
Chris56ford's Avatar
Chris56ford Chris56ford is offline
lost
Chris56ford is gaining momentum as a positive member of FTE.
Take the battery cables off and clean them as well as the battery posts. They will get corroded over time and intermittently make connection.
The clicking you hear is the starter solenoid on the fender. Low voltage will not let it switch and send the power to the starter. Also check and make sure your batteries are charged up.
Old 06-11-2014, 12:36 AM
Batteries are charged up and I did replace the starter selenoid on the fender about 3 months ago because of it doing this same thing. I hooked a charger up to it and set it to 225amps while trying to see if it would help it get enough current to start but no luck there either. I layed on the floor board and listened to the clicking under the dash but it was dark so I could not make out which item it was under there. I did wiggle a bundle of wires under there and it caused the clicking to stop and then I moved them back and it would start again. I will see if I can figure out where those wires go tomorrow in the daylight and get back with you. Thanks!
Old 06-11-2014, 09:40 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Along with the battery terminals and cable ends, also check where the ground cables bolt to the engine block, they need to be CLEAN and tight. The fender mounted starter relay is used for the power distribution point for all the power to the rest of the truck. Make sure the wires to the relay, on the side that has the cable from the battery on it are good, with no corrosion there.
Old 06-11-2014, 01:44 PM
I have checked these different connections and all are in good shape. Thanks for all the help so far Chris and Farmer! If anyone else has anything else to add I am all ears!
Old 06-11-2014, 05:58 PM
Have you had the batteries load tested? Test them one at a time, not hooked together.
This is not a load test, but you can check some things out this way. Take a multi meter set to 20Volts DC, and check the voltage at the batteries, with the cables unhooked. you should get at least 12.5 volts. If that checks out, hook the cables back up and check the voltage at the starter relay on the fender. You shold have the same voltage as you get with the batteries unhooked.
Old 06-11-2014, 09:19 PM
I will do that in the morning. Thanks Farmer
Old 06-16-2014, 10:39 AM
I have got it going now. I went back over the ground wires and made sure to wire brush them all and hit the surface they mounted to with emory cloth and it fired up. Thanks guys for your help!
2000 excursion V-10 won't start jistrebe Excursion - King of SUVs 3 07-19-2016 01:56 PM
2003 f350 v-10 no start/ no anything davec570 1999 to 2016 Super Duty 7 12-09-2015 09:16 PM
Truck just died but weird problem lunatech 1997 - 2003 F150 6 12-06-2015 10:18 AM
7.3 sometimes will start sometimes won't 1486LP 1999 - 2003 7.3L Power Stroke Diesel 9 04-29-2013 07:30 AM
02 F150 S-Crew won't start-rythmic clicking under dash echo657 1997 - 2003 F150 4 01-22-2010 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
