Ok This is Strange. - Ford Truck Enthusiasts Forums
Ok This is Strange.
Old 06-10-2014, 09:02 PM
CDone CDone is offline
CDone is starting off with a positive reputation.
Ok This is Strange.
Looked out the back window earlier today and my truck was running, strange this is, I didn't start it. Truck does have an after market remote starter, is it possible someone else was able to start it? When I went out to shut it down I noticed that the CEL was on?
Colin
Old 06-11-2014, 01:06 AM
AceFord7 AceFord7 is offline
AceFord7 is starting off with a positive reputation.
How long have you had the remote starter?
Old 06-11-2014, 06:51 AM
Was already installed in the truck when I bought it used, so at least 3 years.
Colin
Old 06-11-2014, 11:16 AM
mpwbw mpwbw is offline
mpwbw is starting off with a positive reputation.
I would think that few frequencies exist meaning it is entirely possible that although rare somehow you're vehicle started. Remember when garage door remotes were new technology and one could drive down the road and open another's door?
Old 06-11-2014, 12:16 PM
RangerFL1 RangerFL1 is offline
RangerFL1 is starting off with a positive reputation.
It's quite strange and scary too. Do update if this happens again. This might be because of the remote frequency matched with someone else remote.
Old 06-11-2014, 02:17 PM
VTX1800N1 VTX1800N1 is offline
VTX1800N1 is starting off with a positive reputation.
Some aftermarket security systems can be set to automatically start and run an engine for a brief period if battery voltage drops too low.
Sent from my XT1080 using IB AutoGroup
Old 06-11-2014, 08:54 PM
Interesting but not sure if that's what happened, did drive the vehicle earlier in the day.
Colin
Old 06-12-2014, 10:59 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Quote:
Colin
How did you tell it was running by looking out the window? Is it still cold enough there for vapor to show from the exhaust?
Maybe it is doing what VTX suggested and the problem is a failing battery. Would that throw a CEL?
Old 06-13-2014, 08:06 AM
Looked out the window and saw the lights were on (DRL's) Low to mid 70's here, will definitely check the battery though.
Colin
Old 06-13-2014, 09:04 AM
jr105 jr105 is offline
jr105 is gaining momentum as a positive member of FTE.
If your CEL was on did you read the code? That would be your best source of information as to what happened.
Strange noise after shutdown. jermort 6.7L Power Stroke Diesel 104 01-06-2017 11:45 AM
Fixed leaking HPOP and now CEL Boost240sx 1999 - 2003 7.3L Power Stroke Diesel 3 11-26-2015 05:35 PM
Can 2 Misfires with engine light flashing causes 06 Expedition to not shift out of first gear? thegreatgate Expedition & Navigator 8 09-29-2015 10:10 AM
Throwing codes upon cold start only. cw_mi Excursion - King of SUVs 0 05-27-2014 10:27 AM
SCT tuner and still CEL for EGR mylesdixon 6.0L Power Stroke Diesel 7 02-18-2009 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
