99 f250 7.3 powerstroke fuel leak
It's a copper fuel line that starts under my turbo, goes along the middle of the engine to the solenoid just to the passenger side. It connects to something under the solenoid. Just need to know what's it's called so I can replace it. Got fuel shooting out of it where the little bracket holds it. So far I think it's the Tubing, fuel supply Passenger side. Got this info from another forum. Now I'm not sure this is it considering I cannot find a picture of the item, so I don't know if it's the exact thing I'm looking for. Afterall some things on this truck are aftermarket and I don't know if that would be part of it.
SPEC TUBE ASSEMBLY FUEL P
Ford F81Z-9B273-BN
Int'l 1831243C91
I got pictures, not sure how to upload them though. On a mobile too so I don't know.
Ford F81Z-9B273-BN
Int'l 1831243C91
This one? Fuel Supply Line - Passenger's side
Theoretically you could, but you'd still need the rubber Vibralok sleeves for each end, and a flare tool. The lines don't have normal flare fittings. When you reinstall it, either insulate the line from the clamp with a piece of something soft, or leave the clamp off altogether. The clamp causes this problem quite often, unfortunately.
cletis
06-26-2016 06:41 PM
Fordx4jake
06-11-2014 10:36 AM
Fordx4jake
1999 to 2016 Super Duty
06-10-2014 07:52 PM
