99 f250 7.3 powerstroke fuel leak
Old 06-10-2014, 07:57 PM
Fordx4jake's Avatar
Fordx4jake
Fordx4jake is offline
It's a copper fuel line that starts under my turbo, goes along the middle of the engine to the solenoid just to the passenger side. It connects to something under the solenoid. Just need to know what's it's called so I can replace it. Got fuel shooting out of it where the little bracket holds it. So far I think it's the Tubing, fuel supply Passenger side. Got this info from another forum. Now I'm not sure this is it considering I cannot find a picture of the item, so I don't know if it's the exact thing I'm looking for. Afterall some things on this truck are aftermarket and I don't know if that would be part of it.
SPEC TUBE ASSEMBLY FUEL P
Ford F81Z-9B273-BN
Int'l 1831243C91
I got pictures, not sure how to upload them though. On a mobile too so I don't know.
Old 06-10-2014, 08:01 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Old 06-11-2014, 10:41 AM
Fordx4jake's Avatar
Fordx4jake
Originally Posted by Pikachu
That looks like it's it. Not %100 sure because it kinda looks longer in the picture. But back to my question on the other thread I accidentally posted a million times. Would a normal hard line work? I could bend it to fit and all.
Old 06-11-2014, 10:49 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Theoretically you could, but you'd still need the rubber Vibralok sleeves for each end, and a flare tool. The lines don't have normal flare fittings. When you reinstall it, either insulate the line from the clamp with a piece of something soft, or leave the clamp off altogether. The clamp causes this problem quite often, unfortunately.
Old 06-11-2014, 10:51 AM
Fordx4jake's Avatar
Fordx4jake
Would my local ford dealer have the part you listed?
I live in Colorado.
Old 06-11-2014, 10:58 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
I would imagine they'd probably stock it. Diesel O-Rings is in Weldona, about 70 miles NE of Denver, in case you're anywhere in that area.
Old 06-11-2014, 11:57 AM
Fordx4jake's Avatar
Fordx4jake
Alright, thanks! Will keep ya updated on it.
Old 06-11-2014, 12:05 PM
whitetmw's Avatar
whitetmw
whitetmw is offline
Old 06-11-2014, 07:43 PM
Fordx4jake's Avatar
Fordx4jake
Didn't have to take all that out to get the line out. If you have very large hands you probably won't get it out, but yeah. That was it, big ol hole in her. Got a new one for $50 at the local ford dealership. Replaced and running like a champ! Thanks guys!
cletis
06-26-2016 06:41 PM
Fordx4jake
06-11-2014 10:36 AM
Fordx4jake
1999 to 2016 Super Duty
06-10-2014 07:52 PM
davidlea
12-14-2012 10:36 AM
Baja Tank
01-15-2008 05:36 PM
Quick Reply: 99 f250 7.3 powerstroke fuel leak
