The center section is not shaped like the 80s that we are used to now days as they are much beefier.
It is a floater. Sorry for the miss info. I haven't had it apart in years and have had so many others apart lately I just miss remembered. I hate getting old.
The vin plate says the truck should have a 9 inch with 3.0s in it (A1).
Whoa, thats interesting.
Thanks ND
That makes the decoder I was using a liar.
I think that's the first time I've ever gotten misinformation off the web.
That is a Dana 80 center for sure. ford put 8 lug 80's in some E350 and 450 vans with 4:10 gears. dodge also used 8 lug 80's. On the axle tube you may find a build date code stamped in. the 80 cast into the housing is the truth, that's the way Dana marks their rearends.
55f100tx - Can you pass along what years Ford did that in the vans? This gives me an idea. Thanks!
1996 to 1999 E350 1999-2000 E450 They came in the cab and chassis models, look under a U haul. other years may be available. The E450 is wider than the E350 axle.
