1951 F1 - V8 - Engine issues - Page 2 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 11:35 AM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
If the timing light is lighting intermittantly then you have an ignition problem, possibly high resistance igntion wires, worn distributor, or slop in the timing chain causing spark scatter. I would ohm out the plug wires and check for slop at the distibutor.
Old 06-30-2014, 11:37 AM
rneithammer rneithammer is offline
rneithammer is starting off with a positive reputation.
I checked the vacuum line to the wipers...pulled it off the manifold inlet connection and taped the manifold inlet. No change.
Hmm...timing....I can see that the timing advances when the throttle is opened, so I assume that means vacuum advance is working. I did NOT disconnect the vacuum line when I set the base (idle speed) timing. Should I have done that? I'm not sure how that makes a difference, because at idle speed, there would be no port vacuum and therefore, no vacuum advance.
Old 06-30-2014, 11:39 AM
Ignition wires are brand new, from Dennis Carpenter. Is there a specific ohmmeter reading that shows them to be acceptable?
I'll check for distributor play, but it was running fine for years, and then I let it sit......
Old 06-30-2014, 11:46 AM
Hmmm. Most recently, problem has been in the rear cylinders...the ones with the longest wires..... But I have had intermittent firing and dead cylinders in the front, too, just not in this latest go around.
Old 01-03-2015, 02:41 PM
Well, I got it sorted out, with some professional help. The worst part of it was I had the plug wires for # 6 and 7 reversed...doh! That probably happened during one of my troubleshooting soirees. Installed slightly hotter plugs. The real culprit appeared to be the excessively old gas in the tank. Problem solved.
Old 01-03-2015, 02:53 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
So glad ya got it. Most times it the simple things
that stump us.
Old 04-11-2015, 08:26 AM
Larryjr03 Larryjr03 is offline
Larryjr03 is starting off with a positive reputation.
Daddy always said, " Check the simple things 1st." Glad you got 'er fixed !
Suddenly won't run and carb backfires tkisling Ford Inline Six, 200, 250, 4.9L / 300 17 12-22-2016 11:45 PM
'73 EB Won't Start!!!! HELP!!! I Think I've Tried Everything but I Hope Not! bigbeardbiii 1966 - 1977 Early Broncos 8 11-05-2015 02:51 PM
Spark Plugs Changed Yesterday davidzog 2004 - 2008 F150 3 09-25-2015 11:38 AM
5.4 Unusual misfire jpennell1 2004 - 2008 F150 6 06-26-2015 11:29 PM
dead cylinder but good compression? lost_in_space Ford Inline Six, 200, 250, 4.9L / 300 16 03-05-2005 06:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
