Ghost in this sucker
Here's the issues, an intermittent issue. Sometimes the truck will not start, hot or cold. Turns over fine, has 5.5 lbs fuel pressure. You might try to start it 8 times and nothing then boom fires right up. Sometimes it will die while driving, not a stumble like fuel. It just shuts off. Usually it will restart.
It's so intermittent I cant detect if it's spark, I checked it on one occasion it had no spark at the plug. Replaced the plug, tried it again and it started right up.
I suspected the coil and replaced it. Ran good for one day, it has new regulator, new battery.
I stumped guys and don't know what I'm overlooking.
It does however have a "Chinese" knock off electronic distributor from the previous owner.
Had a similar issue with a Crane 700 ignition, turned out to be a heat related intermittent open circuit in the control box. Drove me out of my mind. In my case, when hot suddenly a 6 cylinder turned into a 4 cylinder, or no cylinder. Replaced it with a Pertronix and never had the problem again. Check that distributor?
Lukas2449
18
11-08-2023 04:41 PM
medicpg
08-09-2007 11:25 AM
surfkovo
04-26-2006 07:18 AM
