Cam phaser noise... Gone?!! - Ford Truck Enthusiasts Forums
Old 06-09-2014, 07:27 PM
gccch gccch is offline
gccch is starting off with a positive reputation.
Hi all,
My 2004 f150 with 5.4 has been mine since new. Oil change every 5k with 5w-20. Always well maintained. I have had the clicking noise attributed to cam phaser noise for a long time.
Just drove about 300 miles and thought the ticking may be getting louder... Got off the highway and it definitely seemed so. Rolling along trying to listen while looking for a place to stop it suddenly got dramatically louder. I actually thought it was some other vehicle nearby with loud enough noise to interfere with my listening. Louder and louder until boom, it went silent. Engine is still idling. I thought it blew up and quit. But no, it is idling and driving as good as ever.
Now what? I'm 300 miles from home, need to work in the morning then drive back. My oil has about 3k on it and was low a quart last week, so I topped it off and it is still reading full.
I think it is quieter now than when I left. Any advice?
Old 06-10-2014, 07:53 PM
Drove the truck home today with no issues. The ticking has kept quiet, at least to a level I cannot hear it while highway driving. Very strange how it came and went.
Is there some oil treatment I can use to possibly remove anything that could cause sticking or remove deposits? This is sure to happen again if I do nothing.
Thanks,
Old 06-15-2014, 12:45 PM
Not sure if it is related, but assume so,,,, now I have some codes. P0300, p0301, p0316
Plugs were changed at 100k
Old 06-18-2014, 09:31 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I'll be willing to bet that the ticking noise was a bad cam follower roller and it finally siezed up and got thrown off the valve. That's why it suddenly got louder and then stopped. Phasers make a rod knock type sound that goes away over 1200 RPM. Now that you have a misfire code for #1 I would look there first. Best case is the valve did not get bent when the follower came off and you will only need to replace the cam due to lobe scoring. Worst case is the valve got bent, the spring popped off, and the only thing keeping the valve from eating a piston is the broken valve guide. Just my humble $0.02, it could be something entirely different.
Old 06-22-2014, 02:37 AM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
Definitely should get that checked out ASAP. Any noise like that is cause for a lot of concern
Old 07-07-2014, 10:35 PM
Quote:
Well then.. Thank you for this suggestion. After a few days I stopped looking for replies and have actually put several hundred more miles on the truck. The only thing I notice now is noise upon cold start and it runs a little rough for about a half minute when cold. After I cleared the misfire code it has stayed clear.
I was wondering if it might have been timing chain guides. I read here they often are found broken when doing the cam phaser lock out. Not sure if any of the other symptoms I described would have made sense with that wild guess.
Old 07-18-2014, 09:24 PM
I've decided to wait before looking into the timing chain. I need to read up more on VCT and other subjects here.
I get rough idle when cold, and the CEL has thrown one code for misfire then came on again but went out before I could check the code. It's been a few thousand highway miles since the noise came and went. Mileage is still good. Just changed the oil and it looks as good as any other time, just a few very small sparkly bits which I have seen every oil change I can remember.
Old 07-28-2014, 09:52 AM
Well, the fit hit the Shan as Toby Keith says. Almost 3k of reasonably smooth driving since the above incident and at highway speed this morning I heard some serious noise. I was not sure if it was a truck nearby using his jake brake. Luckily was at a rest stop turn off. Had it towed to the dealer. I'm far from home so will need to get them to diagnose. Loud clanking from the timing cover area.
Old 07-28-2014, 06:33 PM
Tigauto Tigauto is offline
Tigauto is starting off with a positive reputation.
Could be the cam phasers but betting on tensioner, my truck sounded like a diesel. Removed and found the tensioner collapsed, right chain loose. This made the right cam phaser right out to lunch.
Old 07-30-2014, 11:15 AM
The dealer I had it towed to is only interested in replacing the engine completely. I understand it. They have no way of knowing the estimate to replace timing chains will result in a sound engine and don't want to be blamed for missing anything hidden. So I am planning to take it home for dis-assembly.
My biggest question, what could have broken that would lead to valve-piston collisions? That's really the biggest concern, right?
Whatever broke was at high speed, but I was very quick to get off the road and shut it down.
Old 07-30-2014, 11:32 AM
The codes it is reporting are:
P0300
P0301
P0303
P0305
P0316
I think the first 4 are all misfire codes.
Old 07-30-2014, 03:05 PM
Could be chain jumped from tensioner, sized cam, number of things. I have mine on the floor of my shop. Cam scored and cam journal, lobes of cam pitted, tensioner collapsed chain making noise, phasers done. Mine is a 2007 5.4, going with 4.6 with 78,000 km.
Wreckers want 3,000.00 grand or more for low km 5.4. The 4.6 cost me 900.00.
To save time take the rocker cover off, remove cam cap if scored engine is done.
The cams have no bearings so if it's scored don't go any further.
Old 07-30-2014, 04:55 PM
Pull the valve covers and take some pics. I would like to see what broke.
Old 07-31-2014, 02:50 PM
I will be dragging it home over the weekend and hope to get the covers off then. Will post some pics and what I find.
Old 07-31-2014, 04:20 PM
By the way, with codes P0301, 0303, 0305, this is one side of the engine. Which side? Drivers or Passenger? I gather that would be the one to start with inspecting the cams. Then is all looks good move to the other side then the front cover?
2004 F-150 FX4 5.4l Triton Loud Exhaust Leak from Top of Engine? GCosta 2004 - 2008 F150 6 02-05-2016 12:32 PM
What does injector knock sound like? Crazy_Jim 1999 - 2003 7.3L Power Stroke Diesel 15 01-14-2015 05:50 AM
5.42v engine noise jferg92 1997 - 2003 F150 6 08-11-2014 04:57 PM
UPDATE #2 IN OP - Guidance Needed Please - NOT a Cam Phaser Issue Notrega 1997-2006 Expedition & Navigator 31 03-02-2014 07:37 PM
Opinions on engine noise jaluhn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 06-25-2012 11:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
