? - Flushing PS Fluid w/o Motor
My motor is out and I need to replace the low pressure power steering hose because it has a leak. On my F250, the hose connects to some metal lines that snake around the frame. I think those are to cool the fluid. Anyway, my motor is out and I'd like to drain the pump, replace the hose and fill it up before I put the motor back in. I think if I disco the hose from the pump, that I can flush what is in the lines by turning the pulley. My problem is that my motor is out so I can't turn the pulley that way. Can I manually turn the pulley to get it to flush out the old fluid or maybe put a rubber wheel on my drill and turn the pulley that way?
on
Jack up the front wheels, with both power steering hoses off the pump and bent down low as possable to drain , turn the wheels lock to lock a few times.
That will remove most of the old fluid from the steering gear box.
You can refill the gearbox and repeat to really clean it out if you want too.
whiteboyslo
03-08-2012 08:50 PM
ac700wildcat
06-11-2009 11:50 PM
