serviced trans.
serviced trans.
Did it myself today. Truck has 140,000 so it is due. Not a hard job but it takes several hours to do it right. Removed the pan and found it to be very clean, almost scarey clean. Hardly any shavings on the magnet. Very little cleaning needed. This means little wear on the trans., even at 140,000 miles! Installed new filter and fluid and put it back together. Test drive and all is well!
Now I gotta do the rear-end.
No I did a simple drain of the pan course I remove the pan and everything but next time umm I'll probably do it in about another 50,000 miles from now I won't wait so long
It's just amazing how clean the trans. was. It must be the Mercon LV fluid. Don't ever use anything else...............cheers!
emspjay
12-10-2014 06:14 AM
Truckie256
03-09-2014 07:41 AM
2000F2504X4
02-15-2013 09:04 PM
ovenrat
08-11-2003 06:14 PM
