serviced trans. - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
serviced trans.
Old 06-09-2014, 01:49 AM
Flatbed Ed's Avatar
Flatbed Ed Flatbed Ed is offline
Flatbed Ed is starting off with a positive reputation.
serviced trans.
Did it myself today. Truck has 140,000 so it is due. Not a hard job but it takes several hours to do it right. Removed the pan and found it to be very clean, almost scarey clean. Hardly any shavings on the magnet. Very little cleaning needed. This means little wear on the trans., even at 140,000 miles! Installed new filter and fluid and put it back together. Test drive and all is well!
Now I gotta do the rear-end.
Old 06-09-2014, 06:21 AM
LCT LCT is offline
LCT is starting off with a positive reputation.
Your 12' truck has 140,000 miles?
How is that possible? Godsake that is some serious truckin!
Old 06-09-2014, 12:01 PM
Flatbed Ed's Avatar
Yeah well I've had the truck about 2 years now I drive about 70,000 miles a year more or less
Old 06-09-2014, 01:58 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Did you just change the fluid that was in the pan or did you manage to get it out of the cooler and converter.
Denny
Old 06-09-2014, 02:42 PM
Flatbed Ed's Avatar
Quote:
Denny
No I did a simple drain of the pan course I remove the pan and everything but next time umm I'll probably do it in about another 50,000 miles from now I won't wait so long
Old 06-09-2014, 06:43 PM
pacnorwest pacnorwest is offline
pacnorwest is starting off with a positive reputation.
Quote:
That's a goodly amount of miles.
Are you hauling or towing with it?
What kind of load, if any, is it working under?
Old 06-09-2014, 08:41 PM
RZAR's Avatar
RZAR RZAR is offline
RZAR is gaining momentum as a positive member of FTE.
Nice to see the trans is holding up well.
Old 06-09-2014, 08:57 PM
Flatbed Ed's Avatar
I'm a hot shot driver, so it is worked hard. I haul oilfield parts, no towing. A typical load for me can be as little as 200 lbs, up to 8500 lbs. My average load is about 3500 lbs.
It's just amazing how clean the trans. was. It must be the Mercon LV fluid. Don't ever use anything else...............cheers!
Old 06-09-2014, 09:46 PM
LCT LCT is offline
Well this post is a true testament to the durability of the 6.2.
My friend, that is some serious driving!
choosing brake rotors HMS 1999 to 2016 Super Duty 9 01-24-2016 02:05 PM
2008 f250 opportunity freefisherman 1999 to 2016 Super Duty 3 06-11-2015 09:02 AM
94 E250 Stumble and Buck seapointejim 1968-2013 Full Size Vans 0 12-18-2014 12:30 AM
will not shift out of park greenterror Explorer, Sport Trac, Mountaineer & Aviator 4 03-19-2009 06:42 PM
95 7.3, life of the automatic mountaincat68 1994.5 - 1997 7.3L Power Stroke Diesel 3 06-20-2005 07:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
