79 f250 Dana 44 steering knuckles
I'm looking for new steering knuckles for a 1979 f250 hp Dana 44. My drivers side hole is wallered out due to PO'S lack of care. I've searched this site and googled. So far I haven't found a source. Apparently Reid makes new knuckles for the f150, but I can't use them for the f250 because the steering arms are different. Anyone have a source?
Have you looked into companies that sell new ones drilled for crossover? Might be the route you have to go? Have you tried Dorman auto supply, or Rock Auto?
New and $$...Ford Heavy Duty Flat Top Dana 44 Knuckles
" Based on the Bronco disc brake knuckle and fit 1/2 and 3/4 ton brakes"
I would rather stay stock with my steering components. I just replaced all of my tie rods with moog. Using these knuckles would force me to go crossover. These are the Reid ones I mentioned earlier. Does Rock Auto sell stock knuckles? I'll have to look again.
Well when you find them, post up the location for the rest of us. Have you looked into any possible repair of the wallered out hole?
You might just have to ream is out and up size the tie rod end? Or do a tie rod flip?
Rock Equipment Tie Rod Flip Kit | OK4WD
Some choices but not new
http://www.ebay.com/itm/FORD-F250-DANA-44-FLAT-TOP-KNUCKLES-CROSS-OVER-HIGH-STEERING-RIGHT-AND-LEFT-HAND-/370886934952?pt=Motors_Car_Truck_Parts_Accessories&hash=item565a9581a8&vxp=mtr
Ford Flat Top Knuckles
coleprout
05-07-2019 07:18 PM
william16339
09-23-2014 02:16 PM
s.squared-39
13
02-20-2009 10:39 AM
