Propane and new ideas...sort of. - Ford Truck Enthusiasts Forums
Old 06-08-2014, 09:05 PM
77_F150_4x4 77_F150_4x4 is offline
77_F150_4x4 is gaining momentum as a positive member of FTE.
Hey guys, I have kicked the idea around before about propane on the 400 I am building(9.8:1 compression alum. headed blah blah blah). Friend of mine runs one of his 2wd rangers on it and loves it, running a industrial 2.3 works well for him.
Mine currently is set up to run my destroyed to work on a windsor 351 truck lower and a 5.0 truck upper. with the 351m/400 to 351w intake adapters. So yes I plan on running it on EFI but the truck won't ever see snow again unless something is buried and I have to fire it up. I want to say this thing with the set up will be 400 little north of that HP if I remember right the 425 mixing hat is about that.
The crazy idea, I have considered buying a edelbrock dual quad 351w intake modify it so I can use it on my 400. use dual 65mm Throttle bodies then a set of impco 300s that would go above them enclose them in a intake system and just be able to switch the injectors off so I can run it on propane being prices around here are not bad. What do you guys think? crazy?
Thank you,
Curtis
Getting closer, but still far off... 77_F150_4x4 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 06-14-2015 02:36 PM
351w with misfire ring, word of advice. 77_F150_4x4 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 06-25-2014 06:05 PM
NEED HELP.. MILD TURBO PROPANE 5.4 TRITON FUEL SIPPER BUILD DAKIND1 1999 to 2016 Super Duty 8 01-06-2013 01:20 PM
propane powered ford blueeyedfordguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 88 03-13-2010 02:53 PM
Propane Curious FordTrucksKickGM Alternative Fuels, Hybrids & Mileage 6 09-06-2007 10:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
