292 --- Reviving - Ford Truck Enthusiasts Forums
292 --- Reviving
Old 06-08-2014, 08:39 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Moodus Man
ihcc104 is starting off with a positive reputation.
292 --- Reviving
I just bought a 64 F350 with the 292. I took the spark plugs out and put marvel mystery oil in them and let it sit. I tried putting a ratchet and breaker bar on the engine and turning it by hand, but it wont budge. Where should I go next? I am afraid to try to start it and that it will break something. Suggestions?
Thanks Guys,
Cory
Old 06-08-2014, 11:59 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
As you suspect, if it cant be turned manually, the starter shouldnt be used.
I have heard and read of accounts where guys did an initial upper cylinder lube, and then went out each day, manually trying to turn over the engine. One way, then the other, gaining a slight amount of movement each day, finally to break it free.
Personally, I think it is most of the time a waste of time. The times I have done it was with engines out of vehicle. The crank had to be turned to get the engine disassembled, and the cylinders were always a mess. Just take the intake and heads off and see what the problem is. Could very well be a broken head(s) which leaked coolant into cylinders, to sit and rust for years. Or if the engine sat exposed without hood or air cleaner, same deal. Or all could be ok. Then it is an opportunity to clean up rocker and chambers, install gaskets, and see what happens.
One home brew for a WD-40 type lube is 50% ATF and 50% Acetone. I've tried it a couple times on various things and still dont have an opinion on effectiveness. One thing for sure, it has to be shaken immediately before use because the concoction separates very quickly.
Old 06-09-2014, 04:00 PM
tomfiii tomfiii is offline
tomfiii is starting off with a positive reputation.
Did you have any rust on plugs? You can try and use a pry bar on flywheel and see if you can get the motor to move in either direction even if a little,and if it moves just move it back and forth.
Old 06-09-2014, 05:04 PM
ihcc104's Avatar
Moodus Man
I am soaking the cylinders now with that "brew" as well as marvel and PB Blaster. I am trying to eliminate taking apart the engine too far.... I don't know too much about the inner workings other than the basics, valves and pistons and crank. It may be a little above my ability. If this doesn't work, Ill have to dig in deeper. Thank you for the information! I appreciate it.
Quote:
I did have rust on 1 of the plugs, but the other 7 looks like new. Sooo, my guess is that the cylinder with its exhaust valve open is the one that has some rust in it. Where do I pry off of? I tried a breaker bar with an extension on the nut on the flywheel, but it didn't move.
Old 06-09-2014, 05:52 PM
Use the starter teeth on ring gear,just make sure you have a level bite between teeth and a pry bar.how long has it soaked maybe a week or so.
Old 06-09-2014, 05:53 PM
ihcc104's Avatar
Moodus Man
Before I try any prying, I am going to wait a week with it soaking. Maybe it will work its self out. Thanks
Old 07-19-2014, 07:53 AM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Quote:
Don't leave us hanging...
And the status is?
Old 07-19-2014, 08:48 AM
ihcc104's Avatar
Moodus Man
Quote:
And the status is?
KsCop, I have been updating my other thread and forgot about this one. I have since got the engine turning over, I let it soak for 3 days and hit the key and the engine started turning over, but it was popping out the carb. I decided to take it apart. I found out that one of the valves were stuck and subsequently bent a push rod, so I took them out, had the heads cleaned up and started lapping and putting the valves back in last night, hope to get the other head done tonight... and hope to have her running tomorrow.
Old 07-19-2014, 09:07 AM
46yblock's Avatar
Be careful with the long head bolts. The bolts on each end of the heads
are slightly longer than the three inner bolts. Mixing them up would be an assembly error with consequences.
Good Job!
Old 07-19-2014, 09:23 AM
ihcc104's Avatar
Moodus Man
Good Job!
Thank you, I will be on the lookout for that.
Old 07-23-2014, 05:04 PM
ihcc104's Avatar
Moodus Man
Well I got it all out back together on Sunday and it runs just fine now, need to do some carb adjustments as it only runs on choke but it's running.
292 vs 302, and value of 292 MCD46 1961 - 1966 F-100 & Larger F-Series Trucks 14 09-12-2016 09:08 PM
1963 292 Y Block Combatwombat 1961 - 1963 F100 Unibody 4 06-22-2015 10:46 AM
Throttle linkage issue for 1955 F100 w/ 1963 292 jaggermk 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-01-2015 09:12 PM
What oil weight should I use in a 1964 f-100 with a 292? Ki-Adi-Mundi 1961 - 1966 F-100 & Larger F-Series Trucks 16 01-03-2015 10:36 AM
1955 F100 transmission question for 292 install jaggermk 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-06-2014 09:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
