302 vs 351 build
#31
Ha.... You got me on that one. Old heads have the extra bolts. But the late intake works on the early heads. No leak as long as the head isn't drilled all the way through for threads.
Not sure why ford changed that.
You'll want to use a late model head anyway. Gt40 or gt40p. Much better oem head than all the other sbf heads (excluding the Cleveland head that is)
#32
#34
They do have same size valves as the 69 was the better head back in the day. It also has a bigger spark plug.
I have a decent head flow chart somewhere, but can't find the link on my phone.
#35
Most aftermarket cams are too aggressive or have too much overlap for an efi engine to be happy. They make some very nice ones designed for our trucks. If you look for a cam with lobe separation of 112-114, that should be compatible. 112 will have a less smooth idle, where 114 is what the computer really prefers.
#36
69 heads don't have hardened exhaust seats. That can get to be an issue with this unleaded fuel we have now if you tow or do long drives.
I have seen flow chart results from most of the different year heads, and that alone tells you what years you want to find.
#37
#39
Not really.
All 351s are 28oz balance. Older Van engines have more chance to have spot faced connecting rod bolt surfaces, but that's only a minor improvement. It's the same rod. I'd get a. 94+ (Definitely 95-96) because it has a roller cam, and with 1.7 ratio rockers, you can get away with that for a while if you didn't want to do a cam immediately. If you get one from a truck it will already have correct oil pan.
#40
My dad says the exhaust side has the 2.02 valve to get the exhaust out since Fords exhaust side is garbage but I'm skeptical as I have no idea how the hell that is even possible. Compression sits at a nice 9.5:1 on this current engine.
#42
#43
#44
Roller lifters and roller cam. Only the cobra 5liter had roller rockers stock.
If you are going to stick with a 302 then I would suggest just getting a complete explorer motor. It has most all of the good parts that you're looking for but you just need to upgrade the valve springs if you were going to put an aftermarket camshaft in it. If you are going to do a 351 then I would suggest getting a 94 to 96 where it already has the roller camshaft in it. Older than 94 it was a flat Tappet camshaft
#45
