Engine Swap Wiring Harness Issue
Currently working on a 5.4 to 7.3 swap and ran into a snag.
Build Thread in my signature.
Well project standstill I am now trying to figure out a wiring issue. I was under the impression from all sources that the pigtails for 4x4 would be on the dash wiring in the diesel. Which is not the case. Also the truck was manual everything and doesn't have the pigtails for the power module either.
At this point I am back to the drawing board. I may look for a 2002 wiring harness. Will that work with the 2000 Engine? Also I have a NVK4 PCM, will this work with 2002 harness and this has nothing to do with 4x4 correct, just engine and trans?
Will I need the dash as well as bay harness and will I need the fuse panels as well?
You can switch the 4x4 without the PCM. You can do this by using 5 Pin Relays. However, it will be up to YOU not to engage above 50 MPH or Low Range when moving. The feed circuit can be switched with the ignition switch via a relay as well.
The only other issue I can currently see would be the ESOF (if you have it). You would need to convert to Manual Only Operations as the PCM will not be in the signaling circuit.
breken5096
Modular V10 (6.8l)
07-15-2018 01:37 PM
DasCheckers
WTB - Parts & other
11-14-2016 08:07 AM
radramrod2
01-31-2005 05:01 PM
