Australia Chapter Join Chapter , Leader: ChunderDownUnder
Diff oil
Old 06-08-2014, 06:59 AM
Patchy 73's Avatar
Patchy 73
Patchy 73 is offline
Diff oil
Hi All,
I got a leaking rear diff gasket
What is the recommend diff oil after I replace the gasket
Might be a dumb question, I have never replaced the diff oil in my F250
Done it plenty of times on my old F100's
Cheers,
Patchy
Old 06-09-2014, 01:22 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
I use this Patchy.
Full Synthetic 80W-140 Heavy Duty Limited Slip Differential Oil- Nulon Australia
No gasket. Use tube goo.
do ya self a favour and get one of these. Got a drain plug and fill hole with magnetic dipstick.
AFE 10.25/10.5 Rear Diff Cover - Machined Fins - Riffraff Diesel Performance
Old 06-09-2014, 04:00 PM
BigF350's Avatar
BigF350
BigF350 is offline
Also double check the breather tube isn't blocked while you are at it. Its often the cause of leaky diffs, and if not fixed, even with new goo, it will begin leaking again very soon.
Old 06-10-2014, 04:01 AM
Patchy 73's Avatar
Patchy 73
Thanks guys,
A job for this weekend
Cheers,
Patchy
Old 08-29-2014, 09:12 PM
Yowie's Avatar
Yowie
Yowie is offline
Well that answers my question,
There are two different diff covers listed on the Riffraff site and i was not sure what to order. They look like they will make servicing a lot easier.
Thanks Brian
Old 08-30-2014, 05:22 AM
ChunderDownUnder
we have the 10.25 sterling. U can get the machined or non machined surface. Its just the look that is different.
Old 08-31-2014, 06:18 AM
MRPERSONALITY's Avatar
MRPERSONALITY
MRPERSONALITY is offline
quick one I need to do the same but bought the additive as well from ford must I add it to the oil I bought Castrol Syntrax 75w-140 limited slip. and any views on transmission oil too might as well do that while I`m busy
Old 09-02-2014, 01:49 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
I'm using Castrol TransmaxZ in the tranny and power steering
Old 09-02-2014, 10:43 AM
BigF350's Avatar
BigF350
BigF350 is offline
I assume your truck has the ZF5 trans, right?
If so, any synthetic auto transmission fluid that is rated for Mercon V (it should say on the side of the container)
Old 09-02-2014, 12:08 PM
MRPERSONALITY
yea I take that its a ZF5, I will have a look out for that
Old 09-06-2014, 11:54 PM
MRPERSONALITY
Another question, What Diff is in the rear of the 2wd F250. I would like to buy another diff cover,
Old 09-07-2014, 11:41 PM
BigF350's Avatar
BigF350
BigF350 is offline
Its a Ford Sterling 10.25/10.5
Riff Raff are probably your best bet for something like that.
Old 09-07-2014, 11:48 PM
MRPERSONALITY
Thanks man I appreciate, gonna get shopping
theenforcer
25
01-29-2023 06:46 AM
SeaCarr
12-23-2017 07:50 AM
df85732
09-18-2016 11:33 AM
Tym
09-07-2010 09:51 AM
mapmanLI
08-30-2010 08:57 AM
Quick Reply: Diff oil
