Diff oil - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Diff oil
Old 06-08-2014, 07:59 AM
Patchy 73's Avatar
Patchy 73 Patchy 73 is offline
Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.
Diff oil
Hi All,
I got a leaking rear diff gasket
What is the recommend diff oil after I replace the gasket
Might be a dumb question, I have never replaced the diff oil in my F250
Done it plenty of times on my old F100's
Cheers,
Patchy
Old 06-09-2014, 02:22 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
I use this Patchy.
Full Synthetic 80W-140 Heavy Duty Limited Slip Differential Oil- Nulon Australia
No gasket. Use tube goo.
do ya self a favour and get one of these. Got a drain plug and fill hole with magnetic dipstick.
AFE 10.25/10.5 Rear Diff Cover - Machined Fins - Riffraff Diesel Performance
Old 06-09-2014, 05:00 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Also double check the breather tube isn't blocked while you are at it. Its often the cause of leaky diffs, and if not fixed, even with new goo, it will begin leaking again very soon.
Old 06-10-2014, 05:01 AM
Patchy 73's Avatar
Thanks guys,
A job for this weekend
Cheers,
Patchy
Old 08-29-2014, 10:12 PM
Yowie's Avatar
Yowie Yowie is offline
Yowie is starting off with a positive reputation.
Well that answers my question,
There are two different diff covers listed on the Riffraff site and i was not sure what to order. They look like they will make servicing a lot easier.
Thanks Brian
Old 08-30-2014, 06:22 AM
we have the 10.25 sterling. U can get the machined or non machined surface. Its just the look that is different.
Old 08-31-2014, 07:18 AM
MRPERSONALITY MRPERSONALITY is offline
MRPERSONALITY is starting off with a positive reputation.
quick one I need to do the same but bought the additive as well from ford must I add it to the oil I bought Castrol Syntrax 75w-140 limited slip. and any views on transmission oil too might as well do that while I`m busy
Old 09-02-2014, 02:49 AM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
I'm using Castrol TransmaxZ in the tranny and power steering
Old 09-02-2014, 11:43 AM
Quote:
I assume your truck has the ZF5 trans, right?
If so, any synthetic auto transmission fluid that is rated for Mercon V (it should say on the side of the container)
Old 09-02-2014, 01:08 PM
yea I take that its a ZF5, I will have a look out for that
Old 09-07-2014, 12:54 AM
Another question, What Diff is in the rear of the 2wd F250. I would like to buy another diff cover,
Old 09-08-2014, 12:41 AM
Its a Ford Sterling 10.25/10.5
Riff Raff are probably your best bet for something like that.
Old 09-08-2014, 12:48 AM
Thanks man I appreciate, gonna get shopping
ICP Censor Patchy 73 Australia Chapter 2 11-11-2016 06:44 AM
Am i wasting my time Patchy 73 Australia Chapter 11 11-22-2015 04:23 AM
AU Dump Pipe Patchy 73 Australia Chapter 1 10-03-2015 10:50 PM
Front Hub Patchy 73 Australia Chapter 9 05-03-2015 07:29 AM
Tail gate lock Patchy 73 Australia Chapter 6 12-30-2013 05:07 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
