AWD Flex needs new tire - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 06-07-2014, 09:52 PM
cjensen68 cjensen68 is offline
cjensen68 is starting off with a positive reputation.
The driver rear has a nail right on the side of the tire and needs to be replaced. The guy at the tire shop mentioned that some AWD vehicles need to have all four changed. Would I be able to get away with buying just one new tire? The new tire depth is 10/32. Would there be an acceptable tread depth for the 3 remaining tires that wouldn't affect any operations with the AWD? I read concerns from other people about that somewhere else. The only thing I've found so far in the manual is this comment "Major dissimilar tire sizes between the front and rear axles could cause the AWD system to stop functioning and default to front wheel drive or damage the AWD system". What is "Major dissimilar tire sizes?
Old 06-08-2014, 02:43 AM
mpwbw mpwbw is offline
mpwbw is starting off with a positive reputation.
Quote:
Tires with minimal tread, such as one with 2/32nd's, is the minimum required by law. A new tire has up to 14/32'nd's in tread, I believe. So, big differences in tread can exist. I wouldn't go more than a 4/32's in difference. This is one reason frequency in rotation is recommended - to prevent major differences in wear. Depending on tread in other three tires, you may be in a pickle since cars come with a spare but often a different size now. Maybe you can get by replacing only two tires at most and then gain an extra spare if need be? Hope this helps.
Old 06-13-2014, 09:19 AM
I talked with the tech from the Ford dealership I bought the car from and told him my situation. I had 5/32 depth on the remaining three tires and the new tire comes with 10/32. He said it was fine to put one new tire on the car and I won't have a problem. I did put the spare tire on to drive the car over there to the tire shop and it felt different driving it. Then the message came on that said AWD OFF. It cleared when the other tire was put on.
Old 06-13-2014, 01:51 PM
Glad things worked out.
Old 06-29-2014, 03:48 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Some places like tirerack.com will shave a tire to match the other tires.
Snow Chain Recommendations iszatso Aerostar 4 11-26-2015 11:04 AM
2008 escape AWD Tech mustange70 Escape & Escape Hybrid 3 11-23-2015 07:25 PM
'03 Mountaineer AWD tire? SBL15 Explorer, Sport Trac, Mountaineer & Aviator 3 12-03-2014 02:48 PM
4x4 vs AWD mode Comments Truckpilot1329 2009 - 2014 F150 3 01-10-2014 03:22 PM
4X4 AND AWD making noise grip1968 1997-2006 Expedition & Navigator 4 01-03-2014 01:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
