Replacement of Cruise Control/Audio Switches
Hey guys, I need some help. I am looking to replace the audio-AC/Cruise switches on my 04 Excursion. I am having a hard time trying to determine if I need to remove the steering wheel. I have found posts for other Ford vehicles, but not the excursion or F250 with the larger switches. Any help with where to look or a write up would be much appreciated.
Thanks!
Ryan
Thanks!
Ryan
Nope. I just had my CC switches replaced 2 weeks ago. Air bag comes out then the switches. I will not give the procedure for safely removing the air bag since I didn't do it. Follow the proper procedures so you don't die.
I bought factory Motorcraft switches from Amazon for about 80 bucks + tax. I tried to give the business the the stealership but they wanted $171.29 + tax.
Just in case you don't know what an air bag can do to you...
<iframe src="//www.youtube.com/embed/JBcvwWUZ0PA" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
That shows how to get the steering wheel off, but not get the switches out. I'm not sure if they just pop out or what..that's what I am confused about. I know on the cruise control only type of switch they come out after the airbag comes off, but these are set into the wheel itself. The new switches have a plug on the back of them for the wiring.
Thanks again!
Ryan
Thanks again!
Ryan
SpeedThrills
06-22-2019 11:56 AM
jimpeel
10-25-2005 11:51 AM
