I Beam hardware function?
Doing a Drum to Disc conversion on a 1952 Ford F3 Parcel Van.
Replacing nuts and bolts as I go along and have a question about a piece of hardware...
Located on the axle, just behind the bottom of the king pin is a 3/4" nut with a square head bolt going through the casting of the I-Beam.
Looks to possibly be an adjustment to limit the amount of swivel rotation on the front tire so it doesn't rub in the wheel well.
Since the shock absorber and lower bracket has to be reversed for the disc brake install, the shock is adding more "meat" for the stop adjustment to hit sooner than the original setup, being on the other side of the I-beam now.
Any tips on adjustment or if it is no longer needed would be appreciated...
Thanks.
Thanks.
Better Description
I was off on the description.
The bolt is located on the bottom half of the spindle assembly and as the wheel is turned, the flat of the bolt head contacts a flat spot on the I-beam.
It acts like an adjustable stop to not allow the wheel to turn beyond a certain point. Maybe if it goes too far, there is a lock-up of the linkage.
Kyle Wood
20
06-10-2018 09:23 AM
