EGR plate delete on a 1979 7.5l 460 - Ford Truck Enthusiasts Forums
Old 06-07-2014, 12:44 PM
bullnose1985's Avatar
bullnose1985 bullnose1985 is offline
bullnose1985 is starting off with a positive reputation.
[B[Hello all, the old holley 4 barrel 1850 carb needed a rebuild so while pulling it off I noticed that the EGR was a plate sandwiched between the carb base and the intake manifold base.
My question is can I remove the EGR and the plate put carb spacer in its place? Currently the EGR isnt hooked to anything.
What do you think or has anyone had had any experience doing this?
/B]
Old 06-24-2014, 11:31 AM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
You can get an adaptor that will replace the EGR plate. I put the transdapt 2199 on mine. It is a complete kit so you wouldn’t need anything else. They are getting expensive though. They are currently running about $65.00
Old 06-24-2014, 11:36 AM
Quote:
Originally Posted by fasthauler View Post
You can get an adaptor that will replace the EGR plate. I put the transdapt 2199 on mine. It is a complete kit so you wouldnít need anything else. They are getting expensive though. They are currently running about $65.00
Thanks Gary. I ended up just sticking it back on unhooked up of course.
Old 08-04-2015, 05:23 PM
i could get an older non-egr gasket set and fill the egr hole with jbweld. Off the engine of course. Any body ever tried that?
Old 08-05-2015, 08:42 AM
fasthauler's Avatar
Quote:
Thatís an interesting concept. I have over the years used JB weld to patch up all kinds of things all the way from cracked blocks to cracked motorcycle cases. I have even raced motorcycles across the desert that was patched back together with JB Weld. But you still have one problem; a square bore carburetors secondaries will not open on that manifold unless you do some grinding on those secondary holes. I am not sure how the JB Weld will hold up with all that expanding and contracting that the hot exhaust gases is going to make the manifold go through. That exhaust really heats up that EGR hole. Another advantage of the adaptor plate is keeping the carburetor cooler. I added the Edelbrock wood fiber spacer on top of the adaptor plate and it completely stopped the carburetor percolating the gas when the engine is run under hot conditions.
Old 08-05-2015, 06:20 PM
Hi Gary, Thanks for your input. I tried looking for the adapter looks like a carb spacer but has a ear on the side between the primaries and secondary at the mating surface.
Could never find one that completely covered that ear area.
I think after the points that you have made i will go ahead with the pre72 gasket and froget the JBWELD.
Thanks again for your input, Jon
Old 08-15-2015, 12:19 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Doesn't your 79 have a square bore intake and the Ford/holley square bore 4-barrel ?
Old 08-15-2015, 05:18 PM
Hello redroad, yes it dose however its betqeen the primary and secondary on the passenger side a spacer only covers part of the egr hole.
Old 08-16-2015, 01:55 PM
fasthauler's Avatar
My mistake, I didn’t pay attention to his post. The 79 was a square bore. 78 back had the mickey mouse large secondaries. I hope I didn’t throw you off.
Old 08-16-2015, 09:23 PM
My mistake, I didnít pay attention to his post. The 79 was a square bore. 78 back had the mickey mouse large secondaries. I hope I didnít throw you off.
no i am good thanks for interest.
Old 08-17-2015, 12:53 PM
redroad's Avatar
If you don't have the plate then look here ..
86 460cid, Motorcrafe 4-v, is there an EGR delet plate out there? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-26-2015 06:11 PM
EGR base plate on a 460 JJJRoberts 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-24-2012 02:05 PM
blocked off egr plate necesary? Barkin 40s 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 08-09-2010 10:38 AM
Carb, spacer plate, & EGR plate. . .what order??? atomicjoe23 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 03-10-2010 02:03 AM
What is the correct carb spacer 1976 460? Teagar Fuel Injection, Carburetion & Fuel System 4 08-28-2006 12:08 AM
Tags
460, 7.5l, egr, egr delete
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
