Help selecting a MIG to buy - Ford Truck Enthusiasts Forums
Old 06-07-2014, 08:29 AM
irhunter's Avatar
irhunter irhunter is offline
irhunter is starting off with a positive reputation.
First, me: beginner stick and gas welder 30 years ago. Five years ago used the company's Hobart 250 with good results.
I want to do: weld in floors, floor cross members, build seat supports...sheet metal to 1/4" mild steel. No aluminium or SS.
I want to spend <$1k for the whole set up (tank and all). I've decided what I need is a Lincoln or Hobart 190. But, I run into larger, older machines which will be cheaper. E.g., Linde 225 with big tank for 500.
What I want: ease of laying down a quality bead for a beginner.
Anyone with experience with older MIGs and new 190s care to comment about ease of use for a beginner?
Thanks,
Roy
Old 06-08-2014, 09:28 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i looked at a lincoln power mig 200 last year for $800. when i got there the guy was pointing out all hte options. he said it has this, but i don't know what it is as he pulled out a $1600 spool gun.
the machine was his fathers, and the father gave it to him when he moved out of country to take his sick wife back to Portugal to die in her home land 8 years before.
i was not looking for anything fancy either, but was glad i bought it.
the 220 volt welder works 1000 times better than the little 110 volt unit i had been using.
so don't be afraid to look on your local craigs list for older welders.
try it, and if it works you should be good to go.
and remember, you can never have too big a welder, just too small.
and don't turn down a machine if it has the spool gun either.
3 weeks ago the step on the aluminum fuel tank on my mack truck broke off. that unwanted spool gun saved me a lot of money by being able to weld the step back on myself.
anywhere i would have took it would have charged me at least $250 to weld it back on.
i had it fixed in under 1 hour.
Old 06-08-2014, 10:29 AM
irhunter's Avatar
Thanks. Yes, shops, compressors, welders...can't have too much.
I am just worried about ease of use of the older/larger machine relative to the newer/smaller.
Old 06-08-2014, 12:05 PM
i ain't rite
it takes a bit to get used to. the bigger machine has a very sensitive trigger, and welds so much better i had to reteach myself how to weld.
it makes it so much easier once you use the bigger machine that you kinda have to forget "fighting" with the small machine to get things done.
Old 06-08-2014, 12:12 PM
irhunter's Avatar
Thanks. I have budgeted plenty of time and gas/wire for practice.
Old 06-30-2014, 06:27 PM
The other Joe The other Joe is offline
The other Joe is starting off with a positive reputation.
I'm not a expert welder.
I am a good body shop welder. A lot of experience with large commercial machines.
And at home I have a older Miller 110 mig that is great for sheet metal and other auto related stuff.
Just buy a good quality machine. Stay away from the China specials.
Old 06-30-2014, 06:32 PM
irhunter's Avatar
Quote:
Thanks. I ended up buying an older small commercial machine (60% at 200 amps). Welds great, and it came with a big pile of good stuff (big bottle, lots of wire, and such).
Roy
Old 07-01-2014, 05:35 PM
Beechkid Beechkid is online now
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Quote:
Roy
The smart buy!!!!!!!!!!!!!!!!!!!!
welding Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 05-20-2016 04:44 AM
1955ford f100 royleexx 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-09-2015 06:27 PM
Stock steel wheels 1990 F350 irhunter 1987 - 1996 F150 & Larger F-Series Trucks 5 08-01-2015 09:37 PM
Mig welders, anybody have one of these? Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-15-2014 08:42 PM
Which wire size to MIG panels Budman88 Paint & Bodywork 6 03-02-2004 03:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
