Any Computer Savvy Folks Present?
Looking for some advice how to run AE on my Linux OS computer.
I bought the Auto Enginuity PC ScanTool Total Ford Bundle. On the box it says 'for Windows-based computer'.
My computer is a Linux OS. I understand that the AE won't work on Linux. I hear that all I need to do is download Windows onto my computer without removing Linux.
Is this possible?
I don't want to buy another computer if I don't have to.
Has anyone here installed Windows onto their Linux OS computer?
What do I need to do?
Thanks,
Is this possible?
Thanks,
What you're looking for is called WINE. It allows you to install a Windows virtual machine on your Linux system. The other option, which may be a little trickier depending on how your computer is currently setup is to setup a dual-boot system so that at power-on you can choose whether to boot into Windows or Linux. Either way, you'll need a copy of Windows (I think you do with WINE--never used it, just read about it when I set up a Linux box here at home).
Jason
Jason
Jason
Jason
To the OP,
If you have a Windows® CD, another thing you can do is install a "virtual machine" (vm) of it, then "play" it as necessary. I do this when I need to run 'doze for resume purposes, for example.
I run CentOS/RHEL at work and Ubuntu at home, and I flip-flop between VirtualBox by Sun Microsystems (now owned by Oracle) and VMPlayer® software by VMWare®.
IMHO VirtualBox is easier as it lets you create a vm right there, whereas I think VMWare wants you to build the vm using one of their licensed products (e.g. Workstation™) which can then be played on their free player software. I haven't built a vm in a few years now and forget the details so you might verify that, first; also, I believe you can download a free, temporary-use license for their Workstation product but you'd need to look and see what their current policies are.
Oracle VM VirtualBox
VMware Player Plus: Easiest Way to Run a Virtual Machine | United States
I haven't done Wine in what seems like decades (might literally well be) - not since I discovered virtual machines.
Setting up a dual-boot installation is more work than is necessary IMHO especially when Linux is already installed; Microsoft doesn't play well with others and likes to think they have exclusive ownership of your hardware and it'll blow away your Linux installation if you're not careful (and, at a minimum, will replace the boot loader on your MBR). VMs are easy, they're one huge file for the VMs and a handful of supporting config files.
Thread Update
Well, given the information that you folks have shared with me in this thread, I have chosen to purchase a new computer. This is much easier for me since computers are not my niche.
It is a new Toshiba Satellite C55-B i5 8GB 750GB with windows 7.
This will be more than sufficient for my needs.
So THANK YOU to whom have chimed in and helped guide me in my direction.
cjben
13
01-27-2009 08:02 PM
packrat56
15
09-19-2007 10:57 AM
Mike W
06-16-2004 02:05 PM
