OD button
Old 06-06-2014, 07:36 PM
jerwiltho's Avatar
jerwiltho
jerwiltho is offline
OD button
The button on the shift lever wouldn't lock out OD on my 93 F150 with the E4OD trans. I replaced the botton on the end of the lever but that didn't cure the problem. Other than that the transworks as it should. What should I try next?
Thanks, Jerry
Old 06-06-2014, 11:24 PM
Phy's Avatar
Phy
Phy is offline
A common problem is the wires chafing where they exit the shift lever. Take the plastic shrouding off the steering column and take a look...
94iditpuller
04-02-2018 07:11 AM
Dbl A
1999 to 2016 Super Duty
04-08-2017 02:28 PM
jerwiltho
11-27-2013 11:44 AM
TheWhiteBeast
11-30-2010 09:28 PM
PremierLand
02-18-2005 05:06 AM
Quick Reply: OD button
