CV narrowing
I have seen it both here and on the HAMB. I believe that he narrowed the IFS 3 inches and Ryan went 2.75. If you look at the photo you will see the weld seam in the center of the crossmember, I believe that the rest of the suspension (with the exception of the R&P) remains in the stock configuration. Since the frame is custom fabricated there is no way of telling the widths of the frame members or the narrowed front section.
I have done some digging, to no avail, to find a source for the R&P narrowing service. Ryan, can you elaborate on how/who did yours?
Behind bars race cars did my crossmember and rack for $400.
Yes, the rack is cut in the middle. Yes there is fluid to deal with. Yes you can cut and reweld a shaft accurately enough (since the shaft isn't spinning, it is just push pull).
The was Noodles welded mine, he cut it right next to the toothy part of the shaft. The shaft is hollow. He put the ends in a lathe and welded them back together with a piece of steel rod in the inside hollow part to line it up perfectly. Then used the lathe to bring it back down to the original shaft size. He told me it took him about 2 hours to figure out.
He said since the shaft is just push pull, duck tape would probably hold it together so he had no worries about the strength of the shaft being welded.
The outside of the rack, same deal, put a piece of pipe inside, cut, reweld with TIG.
Yes every part of the rack inside of the seals has fluid in it. So far no leaks or any issues.
I think that if you read further (or maybe I saw this elsewhere) that shortening the tie rods introduces bumpsteer. I'm with you Ross, I don't see the draw other than $$$. If I was REALLY interested in these IFSs, I would look into a redesign of the spindle to bring the wheel mounting flange in closer. CPP and others are building many diferent variations of spindles, seems like this would be a no brainer since the market appears to be strong.
Thanks for the details, Ryan, I wouldn't have guessed the rack was hollow. A spigot weld is a different game. Reinforcing it with a rod inside is a big difference too. But around here, I would struggle mightily to find a shop with both the lathe and the welding skills and the will to tackle a job like that. I suspect that is the case in most parts of the country.
stronger setup than mustang 2, with better dual piston brakes, heavier duty parts. Total of $600 invested in mine compared to the alternative of $2000+ for a mustang II front end. Price was a big factor.... isn't it always?
Here is the thread...it appears that the pics are now missing however.
Projects - 1956 F100 Build Thread | The H.A.M.B.
Too bad the pictures are gone. It's just not the same without them.
"HOW TO" Shorten a power steering rack. | The H.A.M.B.
THAT IS MY THREAD
So you guys are in luck, I will try to repost them here soon.
It was easy if you have a lathe or cheap machinist, and the ability to tig aluminum. I had around 50.00 in my whole narrowing process and rebuild.
My plan is to use this to get the thing on the road, and then order a custom one off rack when/if this thing has problems.
THAT IS MY THREAD
