Np435 Question - Ford Truck Enthusiasts Forums
Np435 Question
Old 06-06-2014, 10:21 AM
jason832 jason832 is offline
jason832 is starting off with a positive reputation.
Np435 Question
Next week I'm getting my hands on a 4x4 np435, and transfer case, for a grand total of $200 as I am swapping to 4wd. (the front end is a future project.) My setup now is a 1985 f150 2wd with the 300 and the "4speed manual overdrive" or "srod" or "t170" or "doorstopper" or whatever you want to call it.
My only problem is I'm unsure of the crossmember I need and don't feel like swapping it in, to find I don't have the right one, then play musical transmissions until I find the right one. If somebody could describe what the correct crossmember looks like it would be a huge help. Pictures are of course even more helpful! Thanks
Old 06-06-2014, 03:10 PM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
I haven't done the specific swap you are, but I've had four different transmissions in my truck over time........I haven't had to use a different cross member with any of them.
There are several sets of holes & slots in the middle of the cross member, for the rear mount; & the cross member is reversible in the frame. There are also two different positions drilled for it in the frame rails.
There was one swap (I don't remember which trans now) where I drilled two new holes in the cross member, for the rear mount bolts..........otherwise it has been just 'shift & shuffle'.
Old 06-06-2014, 10:23 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
As Ken says, I think the crossmember is the same, though it may need minor repositioning. I know the trans mount is the same........
Ford may have used multiple bell housing patterns and engine mounting methods, but the trans mounting was pretty standard regardless of what trans (or engine) was used. Even when installing a newer trans that didn't even exist when these trucks were built, the crossmember generally works fine, but may need relocated a bit.....
2wd to 4wd conversion questions. Ron94150 1987 - 1996 F150 & Larger F-Series Trucks 19 01-27-2016 05:56 AM
Will any NP205 TCase bolt to any NP435 Tranny? Ken2600 Clutch, Transmission, Differential, Axle & Transfer Case 5 06-26-2014 04:45 PM
What transfer case shifter do I use? custom1106 1987 - 1996 F150 & Larger F-Series Trucks 1 11-04-2013 04:45 PM
429/np435 to zf5 swap K9spike Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 04-28-2012 05:09 PM
SMOD and NP435 swap flyhound Clutch, Transmission, Differential, Axle & Transfer Case 5 12-15-2003 01:21 AM
Tags
4wd, crossmember, manual transmission, np435, srod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
