1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
weird transmission thing
Old 06-05-2014, 10:21 PM
fishernut's Avatar
fishernut
fishernut is offline
I have a 99 f350 7.3L auto.
The trans has started to shift funny. At the top of each gear as it is shifting to the next it flares, rpm's raise a bit then shifts. After the shift, it waves or pulses, like slight rpm surges before it finally settles in. I'm thinking the torque converter is acting up but I'm no mechanic. Any ideas?
Thanks
Old 06-06-2014, 12:15 AM
EXv10's Avatar
EXv10
EXv10 is offline
Thanks
It sounds like slipping clutches, not the converter.
Old 06-06-2014, 05:32 PM
fishernut's Avatar
fishernut
how serious is that, financially speaking? Can that be fixed from the outside? Adjusting the bands?
Old 06-06-2014, 05:42 PM
EXv10's Avatar
EXv10
EXv10 is offline
No there is only one band in that trans and may not even be adjustable. It's probably losing pressure from a worn front pump and the clutches are deep inside. Take it to a trans shop for an evaluation.
hotrod351
27
10-02-2014 09:04 AM
mwcoleman
20
07-16-2009 08:42 PM
ptr34
04-24-2009 06:10 AM
Quick Reply: weird transmission thing
