changeing spark plugs - Ford Truck Enthusiasts Forums
Old 06-05-2014, 09:37 PM
Jerry Kirk Jerry Kirk is offline
Jerry Kirk is starting off with a positive reputation.
I have a 2007 fx4 with a 5.4 . I am going to change the spark plugs out so I was wondering is there any tricks that I could do. I know if your not careful they will break and then you have to get an extractor. any suggestions?
jerry
Old 06-05-2014, 09:53 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I have had mixed results with all procedures on the crap design plugs . My best for the crap design plugs... Warm engine up . Pull coils . Put Seafoam Deepcreep penatrant in each plug hole . Let sit over night . Best of luck ! Broken ones are not hard to remove with the Lisle tool though . So I do not worry too much . Maybe someone else has other thoughts though ....
Old 06-06-2014, 08:25 AM
RangerFL1 RangerFL1 is offline
RangerFL1 is starting off with a positive reputation.
Hey. I have a 2006, recently I tried to change the plugs by myself it was not that easy. I would advice to get it changed from mechanic Or may be you wanna try JWC 3 procedure (Sounds easy though)
Old 06-06-2014, 10:53 AM
MikeAF93 MikeAF93 is offline
MikeAF93 is starting off with a positive reputation.
With a cool engine, use a small amount of PB Blaster to soak the plugs (the stuff works where others fail) and then wait half an hour. Work very slowly. Get the Lisle tool first as even if you are careful, you may still break one or two. I broke two of the eight. If you have it and don't need it, great, but if you don't have it and need it, you're up a creek without a paddle.
The back two on the passenger side will be much easier if you remove the computer harness.
Also, shop around; the plugs range from $11.99 to $21.99 each depending on where you buy them.
As for paying someone to do it, Google search and you will see horror stories of what it cost after plugs broke. Don't know if they're accurate but it convinced me to do it myself. My problem was that after reading about the plug issue I waited until after i got the flashing check engine light to do the plugs. Ended up with a blow catalytic converter.
My 100,000 mile plugs actually lasted 100,105 miles when i started getting misfires. So if you're far below that you may have a while.
Old 06-08-2014, 08:31 AM
thousand_mile_stare thousand_mile_stare is offline
thousand_mile_stare is starting off with a positive reputation.
Old 06-10-2014, 11:02 AM
Thanks for the reply's and the info. Now I just need to make my self do it.
Old 06-11-2014, 11:21 AM
Best of luck !
1999 F350 4x4 transfer case JerryWieland 1999 to 2016 Super Duty 3 01-18-2017 09:47 PM
will this work? jerryst 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-24-2016 12:28 PM
Turn siganl replacement FordHarleyTexas 1967 - 1972 F-100 & Larger F-Series Trucks 14 11-26-2014 10:56 AM
Question: Independent Rear Suspension on mid-50's jerry_s 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-22-2013 04:48 PM
2003 Expedition wont start Jerry Hendrickson 1997-2006 Expedition & Navigator 19 05-06-2013 02:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
