Advice on making my engine more powerful - Page 2 - Ford Truck Enthusiasts Forums
Old 06-08-2014, 06:21 PM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
Check out this link to Horsepower TV. They take a 4.9 to a higher (maybe highest) level. 306 ft/lb and 203 hp. Pause the video on the first dyno graph and you will see the torque is falling sharply at 2500 where the dyno starts recording. The peak torque is somewhere between 1500-2000. They have extended peak horsepower out to 4200 with a wide power band. This engine will drive like an electric motor, strong from idle to 4500.
By comparison my 7.3 N/A diesel is rated 360 fl/lb @1400 and 185 hp @3000. It is a stout motor but still no racer.
Hopping Up an Old Skool Six Part 2 | Engine Power | PowerNation TV - Full Episodes
Old 06-08-2014, 06:49 PM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
All the people over on fordsix.com were saying there was a lot more left and they didn't do much or anything right on that engine. If I remember right, they never fix much to the head.
Old 06-08-2014, 06:54 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Cool video but it's also a painful demonstration of why you don't even bother trying to get more out of the old farm tractor motor, all that work and it doesn't even make the HP and torque a bone stock 5.8 does.
Old 06-08-2014, 08:12 PM
UNTAMND's Avatar
UNTAMND UNTAMND is online now
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Quote:
Originally Posted by Phil Woolfson View Post
Spray some Kroil
I miss kroil. You gotta buy it online now or something.
That stuff is the best (or the old stuff was anyway, rules have changed since 20 years ago)
I'd suggest turbo. If someone was all dead set on rebuilding and making power from a 300-6, I say port the snot out of the head, bigger valves and focus on exhaust. Then build a turbo setup for it using a 5.9 cummins turbo and whatever intercooler you wanna stuff in front.
But yeah, not much to gain from all your work and money if you leave it n/a.
Old 06-09-2014, 12:53 AM
Quote:
4.9 vs 5.8, you would expect more from 20% more displacement and nearly 25 years of technology development. And you will be spinning the 5.8 another 1000 rpm to get those numbers. If your are working the truck all day long it is nice to have the power centered around 2000. If you use the truck as a car most of the time you will love the 5.8, just spin it up when you need the power.
Old 06-09-2014, 07:24 AM
Conanski's Avatar
And you can have more without much trouble or expense and no you don't need to spool it to 3000rpm to get it.
Old 06-09-2014, 07:36 AM
Jarryd's Avatar
That's why I said for the same money, you can swap in a 351 and make more power and not be maxed out.
You could easily pick up a low mile 351 from anywhere, throw in a nice cam that doesn't ruin your low end, throw on some gt40 heads or better if you choose to do so, and you have a hell of a strong truck for the cost of a turbo and tuning in the 4.9.
I was going to but a 4.9 block and build it, but it seems like such a waste after I looked at the outcome.
Old 06-09-2014, 10:16 AM
Holmesuser01 Holmesuser01 is offline
Holmesuser01 is starting off with a positive reputation.
This is entertaining reading.
I've owned a total of 3-4.9L six engines in trucks. They have all kinds of torque at the low end, where it's needed.
My latest 4.9 is a '94. It's slightly weaker than the old carbed engines, but can still hold it's own.
I don't understand the need for more power from an engine that was never designed to do what you guys seem to want to do to it.
I'd own another 351 engine, but in these days of $4 gallon gasoline, the 351 and the other V8's are a deal breaker for me. My last truck before this one was a 351, and it never got better than 8-9 mpg. I bought it the same week that gasoline did the first jump to $3 a gallon. Awful timing for sure.
I'd rather spend my money on making my truck as nice as I can, rather than spending all my extra funds just keeping gasoline in both tanks, you know?
Old 06-09-2014, 10:21 AM
Jarryd's Avatar
Gas isn't a major concern here. I have a very short commute, I even walk some days. My wife's car gets 40 mpg so we take it when we go on trips. My truck is my toy so I don't care if I get 1 mpg.
Old 06-09-2014, 02:16 PM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
Originally Posted by Kregj View Post
I have a 300 inline6 4.9l in a 96 ford f150 4x4 and I want more horsepower. What could I do that is reasonably priced???
I've seen some sixes scream (we built one years ago that had over 350 hp) and smoked a built 383 Road Runner (in its first race at the track)...........here are some ideas:
Ford 87-96 4.9L (300) EFI Fuel Injector and Pressure Upgrades
Alternatively, locate an older six and try this:
How to Upgrade Performance in Vintage Mustang Six-Cylinder Engines - Mustang Monthly Magazine
Old 06-09-2014, 04:40 PM
Quote:
460 F250 can be had for $2,000 to $3,000 in South Texas. The 4.9 F150 will go for 3,000-4,000. If the 4.9 is not what you want then trading trucks would be the easiest solution unless it has sentimental value or is in exceptional shape.
Old 06-09-2014, 04:43 PM
Jarryd's Avatar
My truck is in exceptional shape and I had every intention of building an engine when I bought it. I actually sold my previous engine to pay for the whole truck.
  #28
Old 08-03-2014, 03:15 AM
BigSix1 BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.BigSix1 is gaining momentum as a positive member of FTE.
Subscribed, for the high perf. links on the 4.9.
More power Nick Olsen 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 02-18-2016 05:47 PM
Best way to make more boost? corksil 1999 - 2003 7.3L Power Stroke Diesel 24 07-23-2015 08:36 PM
wanting more power fordexpstang Modular V8 (4.6L, 5.4L) 10 01-23-2015 09:42 AM
Extending Fuel Range SouthBoundandDown 6.0L Power Stroke Diesel 4 11-25-2014 11:53 AM
More Power cw974x4 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 0 10-22-2012 07:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
