Where's the gas - Ford Truck Enthusiasts Forums
Where's the gas
Old 06-05-2014, 12:51 AM
300auto 300auto is offline
300auto is starting off with a positive reputation.
Where's the gas
79"150 custom explorer 302 automatic,I have replaced every inch of fuel line doubled up on fuel filters from hard line to the carb and installed a new mech pump can't get any fuel from front tank and barely get any from rear both have plenty in tank blew air into tanks from hard line by fire wall switched inside cab front to rear got bubbles from both tanks what am I missing could switch gone bad are they known for getting stuck between tanks when switched? Any help would be great,thanks steve
Old 07-06-2014, 09:02 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
fuel pump pressure test. if their is even the smallest pin hole forget about fuel flow. make sure the pump has everything it needs to work mechanically. make sure you used the right size lines as that can easily kill any pump pressure. make sure fuel can flow everywere in the system
Tank switching solenoid and fuel line size abstractbart 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-16-2016 04:17 PM
Fuel tank issue 264WSM Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-25-2015 08:54 PM
Dual fuel tankS mike L 1987 - 1996 F150 & Larger F-Series Trucks 39 11-23-2014 09:33 AM
Fuel filter grantkat 1987 - 1996 F150 & Larger F-Series Trucks 3 08-23-2014 01:19 AM
7.3L Powerstoke Tank Switching Problem jjpski 1994.5 - 1997 7.3L Power Stroke Diesel 1 05-07-2014 03:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
