68 f850 super duty
The following users liked this post:
That's right, there was a 475 as well. The 475 was interesting, it was really a 477 intended for the F-800 to make it more competitive against a certain brand X truck who's 427 made a lot more power than the FT-391. Problem was the 475 was only rated at 200 h.p./338 ft. lbs., better than the 391 but still short of the competitor's 220 h.p./360 ft. lbs.. To make matters worse, the 475 ate a lot more gasoline than either the 391 or 427. The real solution for Ford was the truck Lima 429, which was competitive with the 427 and eventually replaced all the Super Duty V-8's. The 475 was dropped at the end of the '79 model year, the 534's lasted in the C and L series until 1981. VERY few were sold in the final years.
As for parts, not much is out there anymore. Tune-up parts, gaskets and water pumps seem to still be around, anything else may require some searching. The Super Duty's have been gone a long time and they were not related to any other Ford V-8, although the design is somewhat similar to the MEL's
Joe when I was a kid I drove this new 1964 534 5x4 for ten years. And
it went another 10 or more yrs after I left. I cant remember anything
other than tires tune ups filters lots of polish & wax. He also had two new
"gutless V6 Cummins" ugg. But my truck usually loaded pulling a trailer
with a dozer on it; 534 didnt care Im passing them Macks loaded on
hills like butter. Who cared at .29-.30 cents a gallon.
Example; a 15yd load delivered was about $25: X 10 loads a day=$250
plus $20 hr dozer X 8hrs = $160
gross $410 8hrs
-$100 fuel
__________
tot $310 per day $1860 6 day wk
thats just one truck not to say about cheap ins, no cdls no bull crap back
then. Oh yea, no. plates about $20 bucks a year. then a truck was a truck
not by the weight baloneie.... thats what I remember... Im just sayin
sam
gross $410 8hrs
-$100 fuel
__________
sam
gross $410 8hrs
-$100 fuel
__________
sam
gross $410 8hrs
-$100 fuel
__________
sam
The 427 Chevy big block engines didn't come out until the mid sixties, by which time heavy trucks were well on the way to Dieselization.
The 427 Chevy is also a modified car engine, and doesn't have the durability of a Super Duty Ford.
The later Super Duty incarnations were emission driven derivatives of the initial design. Unfortunately, the combustion chamber concept was not emission friendly. In the end, high gas prices, low production volumes as fleets switched to Diesel, and the outmoded (for emissions) combustion concept killed the family
Your timing is off: The Fors Super Duties were introduced in the late 50's to compete with the large International V8 gas engines. The Chevy / GMC had the 348 W block and optional Buick / Pontiac engines, but no real gasoline V8 truck engines.
GMC didn't have a heavy duty gasoline V-8, but their V-6 family that came out in 1960 was very competitive, particularly the 478 V-6, 637 V-8, and 702 V-12. The 702's were about as powerful as a gasoline truck engine ever got outside of a Hall-Scott.
The cylinder head design of the Super Duty was indeed a problem as time went on. I remember talking to a Ford engineer after the 534 was dropped and he told me that they had to retard the timing and lower the compression ratio so much on the 534 that it was only slightly more powerful that the Lima 429 but much less efficient!
gross $410 8hrs
-$100 fuel
__________
sam
gross $410 8hrs
-$100 fuel
__________
sam
