Clear Light Housings
I have Looked for a set of Clear cab lights for my 97 f350. It currently has factory installed amber cab lights which I'm still on the fence about. I want to find a set of Clear cab lights. I know they did not come oem but I want to find something that looks similar to the oem's and mount the same.
I also want to replace my front turn signals as well either euro style or diffused. I am trying to get away from orange up front.
Who makes the best looking Clear tail lights?
Thanks for the help guys.
I recommend Depo for the clear corner lights. They fit good and don't look strange like some of the others.
http://www.ebay.com/sch/sis.html?_nk...d=140504130457
For clear lights, I do not like the CLEAR ones, I like the frosted ones(like stock)
APC used to make them but not anymore. You have to look high and low for the frosted ones and be willing to spend some $$ on them
I found 4 pair of frosted front marked last year, I bought all 4 pair
Fior taillights, there again, I prefer frosted and again, they are hard to find. I think I am don to 2 spare pair.
As for cab lights APC USED to make them. I have a old set I found. I had to reglue the lens' to the bases.
LMC sells crappy frosted clear LED ones with chrome bases and they make you cut and splice you harness. the LEDs have been know to fail and you have to replace the whole light, not just a bulb
Complete Performance in jasper TX sells Clear frosted ones as well, but they use the same style base as the OEM and you can use any bulb you want and not cut anything
[QUOTE=Diesel_Brad;14406287]For clear lights, I do not like the CLEAR ones, I like the frosted ones(like stock)
Agreed one hundred percent on the stock frosted lights. The euro style looks to modern and out of place for these truck. Thanks fastback I have been looking on and off for a while. Like I said I'm not a big fan of the roof lights but they are there and if in can make them clear they will be less noticeable. I will let you guys know what I find. I did do the interior led lights last night and am happy so far other than the interior makes them look a little blueish. I posted some pictures in the crew cab only thread . I am most impressed with the door panel lights they light up the ground pretty good. Take a look and let me know what you guys think
FordOwnerJoey
01-21-2014 08:35 PM
