Is this a Stock F350 Rear Spring - Ford Truck Enthusiasts Forums
Old 06-04-2014, 05:17 PM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
Is this the stock 94 F350 Spring block? The block between the spring and axle is approximately 5 inches.
Old 06-04-2014, 05:26 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
4" to be exact and yes, it is original
Old 06-04-2014, 09:13 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Is that your axle? Looks like the axle vent tube broke off at the axle tube mounted vented bolt that secures the brake line junction block.
Whew, that's a mouthful, what the heck is that thing called anyway?
Old 06-04-2014, 09:41 PM
The vent tube is being hidden by the tire holder. the tube extends from the brake junction up to some point on the frame.
F4 auxiliary springs not standard or optional Jolly Roger Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 01-21-2016 05:20 AM
Lift Kit Swap Skyjacker Block for ProComp All Spring - Tech Install Help fordexception Excursion - King of SUVs 20 06-03-2015 10:59 PM
Need some belp Curjo Excursion - King of SUVs 2 10-19-2014 12:29 PM
Stock suspension????? Cj7clay Excursion - King of SUVs 6 09-22-2014 06:40 PM
So indecisive - what would you do? acf6 1999 to 2016 Super Duty 26 04-20-2013 07:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
