Question about hubcaps
I have decided that I want to put this kind of hubcap on my '72 F-100:
I see a few sets of them for sale on ebay and other places. Most say they are for a 16" or 16.5" wheel. My question is, are there more than one size of these caps? If not, will these fit my 15" stock-type rims? I sure hope so because I like the way they look!
THANKS in advance for the help!!
Be careful, these are TWO different diameters of these painted hubcaps: 10 5/16" & 11 3/4."
1967/68 F250's could have either innie or outie wheels. 1969 and later are all outies.
The outie hubcaps are also the same as 1967/77 F350, 1969/74 E300, 1975/77 E250/350.
There are also two different diameters of the stainless steel hubcaps.
10 5/16" diameter - Use with innie wheels: 1967/68 F250 2WD & 4WD (rear only).
11 3/4" diameter - Use with outie wheels: 1967/77 F250 2WD & 4WD (rear only) - 1967/77 F350 - 1969/74 E300 - 1975/77 F250/350.
Wheel cover pictured in post 3 (TYPE 5) was introduced in 1966 F100 2WD/4WD as an option, used thru 1977. Also, standard equipment 1967/77 Bronco.
The 4WD cover, instead of an emblem, has a red plastic ring to allow the hub to poke thru, but...
You have to look close, because there were FOUR difference versions of this wheel cover.
Four different versions were available for 1966 Galaxie/LTD ( ridiculous!), one for F100/150 & Bronco.
The cone could be stainless or painted light argent, the emblem could be red/black or all black. F100/150 & Bronco have a stainless cone w/a red emblem or red plastic ring.
The cover pictured in post 3 is missing its black painted accents.
Well, that stinks! Guess I'll have to pick something else. The Type 3 caps shown above are similar and might be my solution. However it works out, I want a small cap on a black rim with the Cooper tires I have with the big white letters. THANKS again for all the info!! You all are obviously on top of your game when it comes to parts!!
C7TZ-1130-G .. Hub Cap 10 1/2" diameter - Painted argent with black painted accents: 1967/72 F100.
C8AZ-1130-D .. Hub Cap 10 1/2" diameter - Stainless steel with black painted accents: 1968/69 Galaxie/LTD & 1968/72 F100.
