Factory Brake Controller not working - Ford Truck Enthusiasts Forums
Old 06-04-2014, 04:17 PM
wfoskir wfoskir is offline
wfoskir is starting off with a positive reputation.
I have a 2008 F-250 Power stroke with tow package. The truck is equiped with the factory electric brake controller. The braking on my goose neck trailer is weak at best. When I use the hand **** for the trailer brakes alone they work fine. We have checked the connection at the master cylinder and it does not appear to be getting the full voltage/amperage. Is there a fix for that?
Old 06-04-2014, 06:11 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Check all your connections for corrosion....esp. the one at the rear of the truck. Open up the connector and look inside!
Old 06-04-2014, 06:52 PM
RV_Tech's Avatar
RV_Tech RV_Tech is online now
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Quote:
How are you checking output at the master cylinder? You will not get output that is comparable there to manual activation unless you are really hammering the brakes.
For example, you know the trailer brakes are good with full manual activation. You do not get that kind of output with normal truck braking as the trailer braking is proportion to pedal pressure and rate of deacceleration. We get a lot of comments about the factory controller not working, when at times it is due to misunderstanding.
Can you say a little more about how you know it is not working? For example, did it work in the past and not now? Did something change? Are you having a hard time stopping? How big is your trailer and what does it weigh? That information will help trigger more comments.
Steve
Old 06-04-2014, 10:53 PM
I have the trailer on jacks and I spun the tire by hand and stepped on the brakes and nothing happened. I then spun the wheel again and used the trailer brake controller only and the tire stopped. Then I put a test light at the plug on the truck and repeated the process. The light was dim when I stepped on the peddle. I then went to the master cylinder, unplugged the rear plug from the bottom and put the test light on it, it was also dim. I did not have a volt meter, so this was the best I could do. It appears though that it is not getting the proper voltage from the source.
Old 06-05-2014, 12:36 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
Does your brake controller illuminated color turn red instead of green when this happens?
If so, I would bet the connector needs a thorough cleaning and/or checking for proper contact.
Old 06-05-2014, 07:51 AM
RV_Tech's Avatar
If you go to the tech tips at the top of the forum, I did a volt/amperage test a good while back showing how small the controller output to the trailer is by just stepping on the pedal while stopped.
How does your controller do when you are driving and have to hammer the brakes?
Steve
Old 06-05-2014, 08:58 AM
I haven't tried it yet in a driving situation. I have just installed new brakes on the trailer thinking this was the problem and then checked checked the truck. However, from past the brakes never seemed to work that good in driving conditions.
No, the controller never turns colors, it always stays green.
Old 06-05-2014, 10:07 AM
spud57's Avatar
spud57 spud57 is offline
spud57 is gaining momentum as a positive member of FTE.
I could be wrong but I was under the impression your truck needs to be moving for the TBC to fully work when applying brakes?
Old 06-05-2014, 12:46 PM
r2millers's Avatar
Quote:
Again, maybe someone will correct me on both comments but I believe in 2006 it was changed so the controller works at any speed. Before it would only work after the 5 mph circuit activated when the door locks auto locked.
Also, if the controller shows green on the console, it is receiving a signal from the brakes, I believe, by way of resistance in the line, eliminating the truck connection at rear bumper.
Old 06-05-2014, 01:35 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I agree. 2006 would work stopped.
Old 06-05-2014, 04:30 PM
RV_Tech's Avatar
Quote:
Yes, it works on manual, but you do not get close to full power using just the pedal, as the amperage is guided by pedal pressure and an accelerometer. You can not test the TBC doing what the OP is doing.
The output amperage on the TBC in my 2010 when set at 10 puts out about 1 amp using pedal pressure alone. I just put my test box on to verify what I posted a good while back. At the same time, it puts out 12 amps using the manual slide. One amp is not going to do anything when it comes to trailer brakes.
This comes up so often in this forum because I think the TBC is not well understood. The operation is not as transparent as with older controllers and its action is not always obvious. I never feel mine working when it engages.
Steve
Old 06-05-2014, 05:27 PM
BPofMD's Avatar
Posting Legend
One other feature of the TCB in the Ford is that it mimics the anti-lock feature of the truck!
Old 06-06-2014, 09:20 AM
Well, i took it to the dealer yesterday and they said they found nothing wrong. I then went back and hooked it my trailer and it does not stop. I had the vehicle in gear and stopped, i then held the brake controller over and let my foot off the brake. The truck started rolling forward. I am going to test the trailer this morning with a friends truck (dodge). I will then know for sure which is not working.
Thanks for all the tips and advice, I will keep everyone posted.
Old 06-06-2014, 10:19 AM
BPofMD's Avatar
Posting Legend
How fast were you going when you tried it? Did you get on the highway.....
Old 06-06-2014, 12:01 PM
r2millers's Avatar
Are all of your hubs "humming" when the brakes are applied? If not, the magnetic actuators aren't working. I'd go back and check the wiring from the hubs up to the connector again.
It doesn't sound like a short or you'd be blowing fuses.
It sounds like an "open" or a place where there's no current flowing through that point. Amazing the controller doesn't identify that their not working.
trailer, no brakes, no lights, nothing old farm truck Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 12 04-12-2016 10:18 PM
Brake Controller Question deerhunt799 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 10-17-2015 01:59 PM
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 08:25 PM
First tow and trailer brake observations tracyclifton 6.7L Power Stroke Diesel 7 07-09-2015 12:08 PM
trailer brake Homerunking2394 1999 to 2016 Super Duty 17 04-23-2015 12:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
