Fuel Pressure Temperature Sensor range?
Old 06-04-2014, 11:48 AM
bigj-dog's Avatar
bigj-dog
bigj-dog is offline
2005 F150, 4x4, 5.4L, auto, 165,000. Finished up changing timing chains, tensionsers, guides, cam phazers and actuators, plugs, cleaned throttle body, and have a left over code. I lost of the list of codes from before I tore it apart, so I don't know if it was present before. Have code P0182 for the Fuel Pressure Temperature Sensor low input. I have a Mac Mentor (but barely know how to it) and according to the datastream (idling in the parking lot after a 45 minute commute), it was telling me fuel temperature was 417 degrees F, and voltage was about .45v. I'm assuming these are out of range, but I can't find any information as to what they should be. Anyone have any information? Thank you very much.
Old 06-09-2014, 10:48 AM
bigj-dog's Avatar
bigj-dog
bigj-dog is offline
Ended up getting a new sensor because of the code and a lack of findeable information. Did a similar test with the new sensor, says 225 degrees F. I still don't know if that's correct, but the light is off and it seems to run better, so I'm going with it.
Old 11-27-2014, 08:40 AM
auburnmiz's Avatar
auburnmiz
auburnmiz is offline
Fuel Temperature sensor location
Can you tell me where this sensor is? My truck is running rough and I have the same P0182 code. Thanks.
Dave042
1997 - 2003 F150
01-19-2016 09:22 PM
j_blueridge
2004 - 2008 F150
11-18-2012 06:56 PM
mtntop1
04-08-2009 10:22 AM
fordf150guy
11-09-2006 10:07 AM
Quick Reply: Fuel Pressure Temperature Sensor range?
