Fuel Pressure Temperature Sensor range? - Ford Truck Enthusiasts Forums
Old 06-04-2014, 12:48 PM
bigj-dog bigj-dog is offline
bigj-dog is starting off with a positive reputation.
2005 F150, 4x4, 5.4L, auto, 165,000. Finished up changing timing chains, tensionsers, guides, cam phazers and actuators, plugs, cleaned throttle body, and have a left over code. I lost of the list of codes from before I tore it apart, so I don't know if it was present before. Have code P0182 for the Fuel Pressure Temperature Sensor low input. I have a Mac Mentor (but barely know how to it) and according to the datastream (idling in the parking lot after a 45 minute commute), it was telling me fuel temperature was 417 degrees F, and voltage was about .45v. I'm assuming these are out of range, but I can't find any information as to what they should be. Anyone have any information? Thank you very much.
Old 06-09-2014, 11:48 AM
Ended up getting a new sensor because of the code and a lack of findeable information. Did a similar test with the new sensor, says 225 degrees F. I still don't know if that's correct, but the light is off and it seems to run better, so I'm going with it.
Old 11-27-2014, 09:40 AM
auburnmiz auburnmiz is offline
auburnmiz is starting off with a positive reputation.
Fuel Temperature sensor location
Can you tell me where this sensor is? My truck is running rough and I have the same P0182 code. Thanks.
08 trouble codes DieselDenny 6.4L Power Stroke Diesel 0 01-31-2017 09:51 AM
EEC components and what they do Racerguy 1997 - 2003 F150 18 11-02-2016 07:26 AM
'07 w/ P0208, P0308, P0300 ,P0301, P0316 codes TNGuy 2004 - 2008 F150 4 10-13-2016 05:49 PM
Some great sensor information fordpride 1999 - 2003 7.3L Power Stroke Diesel 15 05-23-2016 02:00 PM
Fixing a old F150 4.9LOldFordTruck 1987 - 1996 F150 & Larger F-Series Trucks 5 12-16-2015 12:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
