P0022.. Rough idle primarily in reverse - Ford Truck Enthusiasts Forums
Old 06-04-2014, 07:35 AM
bgibbons60 bgibbons60 is offline
bgibbons60 is starting off with a positive reputation.
2005 f150 Lariat 4x4 5.4
Had phasers, tensioners, chains, guides, and sensors replaced. After driving the truck, it started to get a rough idle at low speeds, primarily in reverse. Changed both vct solenoids with no results. Started to get p0022 code. Changed the oil with motorcraft filter and 5w-20 twice after the work had been done, thinking it might need it. Vct's were a little varnished, but not too bad.
After a couple days of light driving, got a misfire on #3. Replaced the coil and it hasn't been back since.
I am stumped at this point and would take any advice anyone can offer.
The computer show the timing to be at +13 when sitting stopped and in drive. It fluctuates a little, but not much. When the truck goes into a rough idle. The rpm's fluctuate wildly. It seems to be happening more frequently, the more I drive it.
Old 06-04-2014, 03:51 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Did you install the updated VCT solenoids? The part number is in my sig and they are supposed to correct the rough idle. If the new parts are in then check the oil pressure at hot idle. You should have 20psi min for the phasers to operate properly. If it's low then you prob have bearing problems or maybe the oil pickup is blocked with guide pieces if any were broken.
Old 06-04-2014, 06:03 PM
The part number is in my sig? I'm sorry , I don't know what that means. Also, I bought the solenoids from speedway auto parts and changed them myself. I didn't have any broken pieces off the guide. Would you recommend trying an OEM solenoid?
Old 06-05-2014, 07:09 AM
I meant my signature below my posts. 8L3Z-6M280-B is the ford part number for the updated VCT solenoids and yes you should use OEM engine parts. Aftermarket parts are made in china and are not as good as the OEM stuff.
5.4L V8 smelly exhaust/sometimes stumbles at highway speed smooth2904 Modular V8 (4.6L, 5.4L) 3 12-30-2016 06:38 PM
P0022 stalling runs rough after load rs0630 1999 to 2016 Super Duty 5 04-07-2016 07:45 PM
P0022 code shrapnell1 Modular V8 (4.6L, 5.4L) 1 02-04-2015 08:34 AM
Code Help: P0022 and P0345 Johnis 1999 to 2016 Super Duty 3 10-28-2012 12:30 AM
Help! 2008 F150 5.4 with error code P0022 AFMSgt2012 2004 - 2008 F150 0 08-06-2012 06:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
