Rust - Ford Truck Enthusiasts Forums
Rust
Old 06-04-2014, 08:32 AM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
Rust
I usually stay put on the forum section which relates to my '53 F-100, but I need a bit of guidance from you folks here at Paint and Bodywork. My doors have an inner and outer skin. The outer skin has a tight crimp over the inner around the edges. It is then spot welded at these edges. There are weep holes that were supposed to keep water from ponding in between the skins. My weeps got plugged up and I have rust at the door bottoms. (That problem has been corrected.) There are a dozen or so little (1/8' dia) through-rust holes here and there on the inner skin, but the structural integrity of the door isn't an issue. I do have rust that has grown in the joint between the two skins. I know that the proper way to deal with this would be to patch in new panels, replacing any rust areas with new metal. If I where to consider am alternative to the proper way, what would be my best option? I imagine drenching the affected areas with a rust converter and then applying a paint over rust product. I will appreciate the opinions of you folks in Paint and Bodywork. Thanks, John
Old 06-26-2014, 11:08 PM
MP&C's Avatar
MP&C MP&C is offline
MP&C has a good reputation on FTE.MP&C has a good reputation on FTE.MP&C has a good reputation on FTE.
John, here are some inner door repairs, to give you some suggestion.
Inner door repair
IMO if you don't repair this correctly, you'll have a reoccurrence of the rust in a few short years. Any of the "quickie" repairs seldom are permanent.
Old 06-30-2014, 06:19 PM
The other Joe The other Joe is offline
The other Joe is starting off with a positive reputation.
I agree fixing it right is the only guarantee.
Saying that. I have had good luck with inner door panels, tailgates, etc.
In a situation like yours I would clean and treat the rust like you mentioned.
Then I would take a product like Fluid Film. (That's what I use.)
And keep that area treated. And keep a eye on it.
2014 Superduty Platinum Rusting mmarks Paint & Bodywork 0 09-03-2016 09:33 AM
Help with rust repair panel parts list; rear door? Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 9 01-25-2016 07:46 PM
Lap VS Butt welding lower door skin patches.............and ghost lines. clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 04-27-2015 10:52 PM
How would you deal with this rust? jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-31-2014 05:04 PM
99 superduty replacement door panels. What am I looking at? leforrest Paint & Bodywork 2 04-24-2014 08:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
