I have a 2003 f250 with a 5.4 with 261,000 miles on it. question i have will it hurt to go to a 30 weight oil? only reason i ask it is starting to use a little oil and its getting valve noise when its hot. thanks in advance
Changing the oil weight may help. I would think if burning a significant amount try using a 10w30 instead of the recommended 5w20. At the same time the 5w20 will be thinner and lubricate better when cold.
Mine has about the same amount of miles. Napa had a sale on oil but they only had 3 quarts of 5w-20 and 3 quarts of 5w-30 (same brand/make), so I bought what they had and mixed them, figure it should equal to 5w-25 now. She had a tap but has been quiet since doing that.
No issues going to a 5w30, that is what I have been running fo rears and it used to be the spec for the modulars. You will gain nothing running a 10w30 over a 5w30.
It's reasonable to think that, but I've heard the oil stratifies -- separates into layers of 20-weight and 30-weight, like it would in a jar. It doesn't mix uniformly if you combine different weights together.
Now, what the consequence of that is, I'm not sure.
