dirty dages bottle - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
dirty dages bottle
Old 06-03-2014, 11:46 AM
schonauer schonauer is offline
schonauer is starting off with a positive reputation.
dirty dages bottle
I have a black line around the top of my degas bottle,what could this be from.
Old 06-03-2014, 12:23 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Does it have a oily look to the top of your coolant or smell like fuel a bit
Old 06-03-2014, 12:57 PM
Coolant looks clean no oil or smell, truck is a 2000 with 118,000 miles on it.
Old 06-03-2014, 05:25 PM
djed djed is offline
djed has a very good reputation on FTE.djed has a very good reputation on FTE.djed has a very good reputation on FTE.djed has a very good reputation on FTE.
I had the same thing on my truck.
First I had my oil tested at Blackstone - thankfully with negative results. Potassium or sodium levels in the oil would indicate coolant in the oil.
Second, since I am new to the truck, I didn't know if the "soot" was residual from a prior event or symptoms of a new problem. I drained enough coolant (into a clean bucket to put back in) and removed the coolant bottle which I cleaned with soapy water. I could only get a rag into the first chamber so the other three chambers had soot which I couldn't remove. My goal in doing this is to see if the soot returns (which thankfully it has not).
Third, I put on a Dieselsite coolant filter.
Finally, I checked the oil dipstick for irregularities (which I did not see).
I'll try to post pictures later on.
As an aside, my oil cooler orings were recently replaced. I'm sure others will chime in and suggest that oil - coolant crossover often occurs as a result of deteriorated orings in the oil cooler.
Good luck.
Old 06-03-2014, 06:40 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Hmmm.... Did it look like this?
Old 06-03-2014, 08:46 PM
Yes it looks just like that Tugly.
Old 06-04-2014, 12:40 AM
Pictures of my degas bottle before cleaning:
Except for clear condensation, my degas bottle is clean at this time.
Although I forgot to mention it above, I did pressurize my coolant system to 15psi and I didn't see a pressure drop over the 15 +/- minutes that I kept the pressure on. In case it helps, A/Ox4 puts out a YouTube video on how to pressure test the cooling system.
Unless the soot returns, I'm going to assume the soot was from a residual problem. If I were you, I would do the same.
I think the other thing I read about when researching the issue was the potential for cracked injector cups. I believe you can test that by removing the injectors and pressurizing the coolant system. Unless the soot returns, I don't think it's necessary to go there.
Old 06-04-2014, 06:16 AM
Tugly's Avatar
Well.... If it's that... the problem is not easy, or it's really terrible:
In my case, it took two problems in conjunction to get soot into the degas bottle.
1. Leaking copper washer on the injector nozzle or a loose injector.
2. Cracked cup below the injector fuel O-ring.
The "epic" saga is in the injector cup link in my signature.
The really-terrible: It could be a blown head gasket, but these are extremely rare.
Are you getting loud injector knock, bucking and jerking at just the right throttle, and really smoky startup?
Old 06-04-2014, 01:41 PM
No smoke on start up no knock truck runs good,I think I'll clean the ring off the degas bottle and put a new coolant filter on an see what happens.
Coolant reservoir bottle Alfredg56 1987 - 1996 F150 & Larger F-Series Trucks 4 10-09-2015 07:34 PM
1985 pickup washer/ antifreeze bottle needed bossshelby WTB - Parts & other 2 06-10-2015 07:47 AM
Coolant bottle oxt127 6.0L Power Stroke Diesel 1 05-22-2015 01:52 PM
Check degas bottle for exhaust gas Diesel_Brad 6.0L Power Stroke Diesel 4 02-06-2015 05:24 AM
Winter Fuel KDAVID1 6.0L Power Stroke Diesel 9 10-16-2014 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
