General Automotive Discussion
Ford powered Nissan
Old 06-03-2014, 09:17 AM
RL250's Avatar
RL250
RL250 is offline
Ford powered Nissan
I've got some info from the newer F150 and Explorer forums, and now I am looking for a general yea or neigh on this project.
I am planning to swap an OBDII equipped 302/5.0L out of a 96-01 Explorer into my 2004 Nissan Xterra. The X is manual with a 2.4L 4 cylinder. I want to use a ZF 5 speed transmission with attached transfer case. I will be using the Explorer engine harness and ECM for the engine.
Good idea or bad?
Old 06-03-2014, 09:20 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
One question. WHY????????????????
Old 06-03-2014, 01:01 PM
Krochus's Avatar
Krochus
Krochus is offline
I could think of a bunch of better engine donor options than a 5.0 v8 that barely wheezes out 220hp This is the 21'st century. Put an LS in that sucker like any well adjusted human being
By swapping in a 5.0 you're basically recreating a $1500 ford exploder from the 90's. Hardly worth the trouble of a swap
Old 06-03-2014, 01:28 PM
RL250's Avatar
RL250
RL250 is offline
I am actually having difficulty finding a manual transmission and manual transfer case. I want something that is stronger than the VG33 that Nissan offered in it. The LS series does not have a readily available manual 4x4 trans and t-case. I admit the LS is impressive, but I know Ford's pushrod V8's better than any other manufacturer. I am also fully prepared to rebuild the old 5.0 to give me the numbers I want.
Any other ideas, besides the LS or the 5.0 that has a readily available manual 4x4 trans and is OBDII compliant?
Old 06-03-2014, 01:39 PM
Krochus's Avatar
Krochus
Krochus is offline
Folks swap LS motors into jeeps of all makes and models ALL with manual transfer cases and they do it by the thousands.
A manual t-case is not a stumbling block
RL250
09-06-2014 11:33 AM
Country705
04-20-2013 11:04 PM
Arctic Wolf
Bronco II
12-01-2011 12:37 AM
shadybrooke22
06-27-2010 10:23 PM
dubCanuck1
13
12-11-2009 01:29 PM
Quick Reply: Ford powered Nissan
