Need help with hitch for my Flareside - Ford Truck Enthusiasts Forums
Old 06-03-2014, 12:09 AM
nikmish's Avatar
nikmish nikmish is offline
nikmish is gaining momentum as a positive member of FTE.nikmish is gaining momentum as a positive member of FTE.
Hi there,
I wonder if you know or can recommend class 3 hitch for my Flareside.
Recently I bought one (the cheapest and with good reviews) and it's Curt 13310. It should fit the truck with some drilling, but when i tried to fit it I can see that it way low and sticking out about 8 inches in front of the bumper. Plus the spear tire can not be mounted back to it's place.
Here is a picture:
Shipping back the hitch will cost me almost as much as the hitch, so i'm trying to sell it on the CL.
I would like to find a hitch that would look as good as on the newer trucks, flash with the bumper and barley noticeable.
I would appreciate it very much if you could help me find me the right one.
Old 06-03-2014, 01:07 AM
dohc_chump's Avatar
dohc_chump dohc_chump is offline
This space for rent...
dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.dohc_chump has a great reputation on FTE.
I noticed a lot of them are like that. Mine has a universal 3 piece hitch installed and they flipped the middle piece for more clearance. Wish I could be more help.
Old 06-03-2014, 07:43 AM
reamer's Avatar
reamer reamer is offline
reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.
Something like this may need some "modifications" with a torch.
Don't think there is alot out there available for us With flaresides.
My 84' hase one on it right now and looks like yours, gonna put the plasma cutter to it soon.
Old 06-03-2014, 09:40 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I assume the problem is you do not have a step bumper like a regular truck? Most hitches are made to clear the lower step bumper?
You might ask around, there may be a shop that will modify it for you for not much money. Cut the center cross piece out, move it up and back and re-weld it in place. Then trim off the leftovers in the rear. The higher and closer to the frame the hitch is, the stronger and better it will pull the trailer. The only drawback is you will probably have to buy a dropped hitch for the ball for most small trailers, which I guess negates any advantage you might have with the hitch closer to the frame.
Old 06-03-2014, 03:53 PM
nikmish's Avatar
That's how i want it to look like:
Link to Flickr site
Old 06-03-2014, 04:51 PM
reamer's Avatar
I like the paint combo.
Old 06-03-2014, 06:28 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Look for "roll pan" hitch
They are a lower profile
Or if you can weld, cut that one and weld it to suit your needs
Old 06-03-2014, 07:15 PM
nikmish's Avatar
Thank you!
This keyword lead me to this king and it looks very promising:
Amazon.com: Sir Michaels 2577147 Hidden Tow Hitch: Automotive Amazon.com: Sir Michaels 2577147 Hidden Tow Hitch: Automotive
But it's for 2000-2003
There are for:
2004-2012 Chevy Colorado & GMC
2005-2009 Dodge Dakota
2004-2007 Ford F-150
2006-2008 Dodge Ram 1500
Will any of this can be fit with sum cutting and welding?
Old 06-03-2014, 09:05 PM
Franklin2's Avatar
Quote:
Originally Posted by nikmish View Post
Thank you!
This keyword lead me to this king and it looks very promising: Amazon.com: Sir Michaels 2577147 Hidden Tow Hitch: Automotive
There are for:
You are going to buy another one and cut and weld on it? Why not cut and weld on the one you have?
Old 06-03-2014, 09:14 PM
Quote:
Exactly.. F'n stupid 10 letter rule
Old 06-03-2014, 09:30 PM
nikmish's Avatar
My thinking was to make it only wider or narrower, the rest will be untouched.
I'm not the one will be doing the fabrications, i have to find someone...
Rockstar mud flaps installation monsterbaby Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 8 01-04-2016 07:23 PM
SuperTruss: The cure to your hangover Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 08-06-2015 06:18 PM
Hitch fail quincyj34 1987 - 1996 F150 & Larger F-Series Trucks 20 02-11-2015 09:00 PM
Mountain Master air ride hitch Trucker Kev Fifth Wheel & Gooseneck RV Towing 3 03-04-2014 12:02 PM
02-05 factory tow hitch info turborich Explorer, Sport Trac, Mountaineer & Aviator 6 03-20-2012 07:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
