2005 f150 transmission problem
Old 05-24-2014, 11:14 AM
challahan's Avatar
challahan
challahan is offline
I have had the check engine light on for a while now with the truck shuttering and bucking along with loss of power. feels like there is something holding back the power. Just a couple days ago I was driving on the freeway and all of a sudden it felt like I was in neutral, tried to accelerate but the engine revved but wouldn't go anywhere, I clicked the overdrive on and it went into gear and I was able to drive home. Now every time I drive it, it goes a block or two in drive then again feels like neutral, put in overdrive and it goes into gear. Please help!!!! I just put in new ignition coils.
Old 05-24-2014, 02:11 PM
twfish's Avatar
twfish
twfish is offline
Have you had the codes checked yet?
Old 05-25-2014, 09:17 AM
challahan's Avatar
challahan
Ya the codes read multiple misfires.
Old 05-25-2014, 10:39 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
The snap ring for the OD servo prob broke. The piece gets in the valvebody and hangs up the shift valve. The misfires are prob worn plugs and need to be fixed ASAP or you will be replacing cat converters too.
Old 06-02-2014, 12:31 PM
challahan's Avatar
challahan
checking into it
Thanks 70f100longbed. Im going to take to a transmission repair place and tell them what you said. Do you have any idea how much it is to fix this?
Thanks again
Old 06-02-2014, 01:59 PM
stuart1's Avatar
stuart1
stuart1 is offline
Don't go into a place with what may be incorrect advice.
Let them figure it out.
If it comes back as what you are told ok.
It may be something altogether different.
It may only need a widget worth $1.49. But if you are prepared for XXXX times that and tell them what your neighbours uncle three times removed said they may say, "hmmmmm".
Old 06-02-2014, 02:56 PM
ojai150's Avatar
ojai150
ojai150 is offline
Thanks again
I had the servo ring snap on my 04 5.4 and I told the transmission place I suspected that was the problem (from information on this board) but they pulled it out and took it all apart and said "well yes , it DOES need the ring but there is other wear also , so I got it rebuilt for $2500 , if I had it to do over , I would have had them just drop the pan and see if the snap ring was broken and replace it , there is a great video on here that shows what a simple job it is . In the future I would just replace it myself .
Old 06-02-2014, 03:50 PM
70f100longbed
Thanks again
The problem with taking it to a trans shop for the snap ring is now since they have been into the trans if anything else fails its their fault and the customer will want it fixed for free. That's why most shops will try to sell you a complete overhaul or reman trans. I have seen it many times. It's not hard to pull the valve body and fix it yourself. You might get lucky and find a shop that will replace just the ring.
Old 06-02-2014, 06:30 PM
ojai150's Avatar
ojai150
ojai150 is offline
yes , this is true , if I had it to do over again , I would have changed it out just like in the video , if it only went another 30,000 so what ?
Old 06-02-2014, 06:33 PM
ojai150's Avatar
ojai150
ojai150 is offline
After they R&R'd the trans , I had a clunk , I searched in here and told them they didn't grease the driveshaft enough , OH NO !!!! what does the INTERNET know ,....they pulled the cover off the pumpkin, showed me , they said the ring & pinion was shot , I said bull**** !! put it back together charged me $90 but they had taken the driveshaft out to inspect the u joints and re greased it it was SILENT !!!! who knew !!!
manwithavan
30
07-11-2017 09:16 PM
Laneely84
10-27-2015 05:12 PM
schamsy
2004 - 2008 F150
04-04-2013 07:43 PM
contourdesigns
10-27-2008 10:43 AM
mhadley
08-27-2004 06:50 AM
Quick Reply: 2005 f150 transmission problem
